Analog multipliers? Dividers?
Papabravo
Joined Feb 24, 2006
22,115
This is Homework Help, not homework done for you. Where is the demonstration of the effort you have expended so far on this problem?
Papabravo
Joined Feb 24, 2006
22,115
AFAIK there is nothing in the problem about mixers and opamps. There is nothing for you to learn except basic algebra to attempt the proof, and this is an emergency on my part -- why exactly?
Papabravo
Joined Feb 24, 2006
22,115
Will somebody please explain how the proof that
\( \frac{a^2\;+\;b^2}{ab\;+\;1}\;=\;c^2\)
has any connection to circuits
Oh great -- a new way to show errors is to center the TeX input in a little rectangular box. The old was far better. I'm just sayin'
If it is not toooo awful much trouble could you fix the TeX rendering in the blogs as well?
Zeeus
Joined Apr 17, 2019
616
\(\frac{a^2\;+\;b^2}(ab\+\;1}=c^2\)
Oh great -- now TeX rendering is well and truly broken -- great job guys
If it is not toooo awful much trouble could you fix it in the blogs as well?
No no...The proof has nothing to do with circuits : just need the multiplier circuit to test the result
Papabravo
Joined Feb 24, 2006
22,115
I see. Thanks for the clarification. Testing the proposition with analog circuits will certainly be a challenge considering that the theorem as stated is true only for integers. It is not necessarily true in the domain of real numbers. Are you ignoring this or did you overlook that detail?
I also observe than none of the 16 Pythagorean Triples with c <= 100 satisfy the condition.
Zeeus
Joined Apr 17, 2019
616
Suppose we apply a sine wave as input 1 and 0v as input 2 : what's output if not a sine wave squared?
or 0v and 2v...output is 4v?
Jony130
Joined Feb 17, 2009
5,601
\[\frac{a^2\;+\;b^2}(ab\+\;1}=c^2\]
TeX works just fine.
\[ \frac{a^2+ b^2}{ab+1}=c^2 \]
Papabravo
Joined Feb 24, 2006
22,115
I'm not sure what you are getting at here. A sine wave varies continuously between a positive peak value and a negative peak value. At some point it must be zero. What happens when you divide something by zero? There is literally no connection between integers and sine waves.
BTW can you find any integers a and b for which the proposition is true?
Zeeus
Joined Apr 17, 2019
616
BTW can you find any integers a and b for which the proposition in true?
No can not except the trivial cases with a or b = 0 or a = b then c = 1 and a = bc
The proof uses "infinite descent" :
Assuming there's a solution (a,b) with minimum a then from vieta jumping..........
Let's leave the math for 'high school' kids
Wanted to test something but pointless now : back to Electronics stuffs 120v, buck converters..etc
Actually google "vieta jumping" the same question is there...if the denominator is changed to ab-1 then yes possible to find solutions except trivial cases
and sorry late response : not great day
Papabravo
Joined Feb 24, 2006
22,115
Thanks for the link. I had not heard of the method before, especially in regards to hyperbolas in quadrant 1.
