analog communication circuit
ValarVictorius
Joined Nov 17, 2015
19
i need the circuit that will transmit and receive 2 message signals with same bandwith in same time with minimum bandwith
how can i build that i need help
AlbertHall
Joined Jun 4, 2014
12,663
What messages?
In what time?
Over what distance?
Over what medium?
If you want minimum bandwidth send your messages vveeeerrryyy sslllooooowwwlllyyy.
ValarVictorius
Joined Nov 17, 2015
19
Messages : Information Signs giving on same time.
Distance : I'll try it on Emona Datex Kit.
Speed : Same time.
My purpose is transmit and receive 2 information signs(they have same bandwidth on same time), in minimum bandwith at same time
AlbertHall
Joined Jun 4, 2014
12,663
I am not much wiser.
To transmit two signals simultaneously you could use a similar method to the stereo FM broadcasts which transmit two separate channels simultaneously. For minimum bandwidth use a very low carrier frequency like 0.0001Hz. It will take a relatively long time but the times will be equal.
12,299
Your information is very not useful. Are you asking about communication over wire, like a serial port, or wireless, like radio?
12,299
Using my secret powers, I can see into the future. I see that after 47 posts we still have no idea what you want to do or why. No overall project details, no circuit requirement details, nothing. Please re-read your post #3. It says nothing useful.
Based on what you have told us so far, a simple telephone line will do what you want.
38,952
One of the toughest part of any engineering project, no matter how small, is proper, clear, and complete specification of the requirements.
You need to work on that.
12,299
Borrowing (and modifying) a page from late-70's broadcast video cameras, you can use triax cable. It has one center conductor and two isolated concentric coaxial shields. The outer one is GND. The inner shield has a positive DC voltage to power the remote location circuits, plus AM or PWM one data signal. The second data signal goes down the center conductor on an FM carrier.
