amplitude modulation explain
mrmike612
Joined Dec 1, 2012
11
if anyone knows please explain for me,my modulating signal is square from 0-5v
the voltage of square with vbias,how does it work to affect the vgs.
how do i have to choose vbias to make sure it works on reverse-biased
33,325
Since this is YOUR homework, you need to show what efforts you have made thus far to solve it. We can then look over what you have done right, what you have done wrong, and find a way to get you back on track and moving a bit further down the road.
mrmike612
Joined Dec 1, 2012
11
hmm....okay....I have some confusions about vbias so I need to make it clear first.I'm not asking for solutions,I'm asking for explaination because i got stuck at my idea.
My thought was ...square wave fluctuates between 0-5v and to make jfet works as voltage resistor control,we should make Vgs<Vp because the maximum resistance shows at Vgs=vp
But when we have square and vbias at the same time.how do i identify the voltage Vgs.Thats what I m' confused
38,929
Since there is so much variation between FETs I expect you will have to experimentally determine the best bias point for that circuit for the particular transistor you have.
