amplifying a 5v digital signal to 13v digital
JCOX
Joined Nov 29, 2011
136
Is there a IC chip that the Vdd can be attached to 13v, that can receives a 5v to 0v digital signal and send the same digital signal out as 13V to 0v?
I have 6 digital inputs that need to be converted to 13v digital.
steveb
Joined Jul 3, 2008
2,436
The 7406 and 7407 chips are inverting and noninverting (respectively) buffers (6 of them) with open collector outputs. The open collector output allows you to apply higher voltage to the output side. You still need to power the chip with the lower voltage (5 VDC), but you have more freedom on the output.
http://pdf1.alldatasheet.com/datasheet-pdf/view/50893/FAIRCHILD/7407.html
JCOX
Joined Nov 29, 2011
136
Thank You. Can you elaborate how it takes a Vcc of 5v and amplify it to 13v at the outputs?
Here's what I want to do but use an IC instead of 12 separate transistors:
JCOX
Joined Nov 29, 2011
136
the signal will change, the fastest would be 2.5ms, and the 13v load is going to a gate of a FET (IRF540), so not much current is needed at all.
JCOX
Joined Nov 29, 2011
136
Would it not be better to use a logic gate mosfet like the IRL540?
I have attached both datasheets for comparison.
I thought the minimum gate source was 10V, can I us these to put 5v to the gate and 13v to the source?
34,411
I would use the 7406 or 7407 chips as steveb suggested. They are cheap, will do what you want, and requires only one chip (and six resistors) to convert your six signals.
JCOX
Joined Nov 29, 2011
136
I'm having trouble understanding... with a 5v input what determines the 13v output? can you sketch a quick schematic so I can understand?
steveb
Joined Jul 3, 2008
2,436
You use a pull up resistor on the output pin. Just tie that resistor to 13 VDC. The datasheet shows how to calculate the resistor value.
I don't know your application well enough to know if it will work well, but it is worth checking it out because the solution is very cheap and very convenient. I don't see any reason why it won't work given your low speed requirements, but you really need to prototype it and test it to be sure.
