Hello!
I am currently constructing a cough-sensor in which I used a piezoeletric sensor (obtained from a beepin-card, I don't know any further info about it):
I now want to be able to use it to arduino.
But I have 2 problems:
1) The signal has low amplitude (200 mV). I have tried to amplify it with an OP07 and with a charge amplifier (as shown below) but I have failed!
The signal has an amplitude of around 200 mV, with a frequency ranging from 0Hz (lets assume) to 0.6 Hz.
What kind of amplifier (it has do be breadboard compatible!) can I use and what kind of montage?
2) How do I offset the signal? I have also tried a simple resistor summation circuit but it failed also!
Thanks in advance!
Thanks in advance!
