Amplifier power dissipation excercise
andrew74
Joined Jul 25, 2022
263
Hi! I am having some difficulty solving this excercise:
An amplifier operates with a single 15V supply, delivers a peak-to-peak amplitude sinusoidal signal of 12V to a 1k load, and absorbs negligible current from the signal generator. The continuous current supplied by the 15V supply is 8mA.
What is the power dissipated in the amplifier and its efficiency?
(results: 102mW and 15%)
In the resolution pictured below I have assumed zero input power, because I have no data on it in the text20220728_093518.jpg
I solved it by recalculating using \[ V_{RMS} \];)
MrAl
Joined Jun 17, 2014
13,764
In the resolution pictured below I have assumed zero input power, because I have no data on it in the textView attachment 272415
Is your entire post showing up?
To calculate AC power you have to convert peak to RMS. Do you know how to do that with a sine wave?
Your power result for the output is incorrect so far.
andrew74
Joined Jul 25, 2022
263
Yes, I was able to arrive at the result by using the RMS value in the calculations.
Thank you!
