thank you!Yes BD is medium power bjt. So you nedd to add real power BJT to achieve 20W.
For example you could replace BD stage with this output stage
I suggests use diagram C output stage
P= I squared times R9 or V squared divided by R9 or V times I in R9.is power accounted with the formula of avg(-I(R9)*Vout)?
Simply calculate the max current in the power transistors when the 4 ohm speaker has an output power of 20W then calculate the heating in the power transistors to see if they can withstand the heating when they have a suitable heatsink.(will 20w be ok with only these pwr bjts?)
First you must learn about what is negative feedback. Didn't you learn about it in school?? It is NOT in series with R9.where should i put the feedback resistor? serial to R4?
Most audio amplifiers have an output impedance of 0.04 ohms or less. 0.25 ohms is easy if you understand about negative feedback.I am still in doubt that these two circuits will suply Ro<0.25ohm.
I don't think that OP knows what bootstrap is.R9 needs to be bootstrapped so that its current doesn't drop to zero when it must supply plenty of current to turn transistor Q5 on. So the output swing is only about 9V p-p which makes a max power in the 8 ohm load of only 1.2W instead of the required 20W.
I think you mean 12.85Vp not RMS20W in an 8 ohm load is a signal of 12.56V RMS which is a swing of 35.8V p-p so the amplifier needs a supply of about 45V, not just 15V.
It is easy to look at Bootstrap in Google. A constant current source could be used instead of bootstrapping.I don't think that OP knows what bootstrap is.
No.I think you mean 12.85Vp not RMS
Ok I see you use RL=8ΩNo.
Real power is rated in RMS, not peak. Peak Power is Mickey Mouse Power. Peak power is double the real RMS power.
Then you made an oscillator instead of an amplifier.I forgot to add Miller compensation capacitor
No oscillation occur, in ideal world of PSpiceThen you made an oscillator instead of an amplifier.
