AM Modulation with 555 timer
Patrishayeah
Joined May 30, 2019
15
I'm currently working on a project in which I generate a carrier wave with the colpitts oscillator and a square wave with the 555 timer. I want to modulate the output of the 555 timer onto the carrier wave so that I can receive it with an AM radio, but don't know how. I've tried different things already with simulations, but none seem to work. Could someone please have a look at the two circuits (I'll leave a link and picture below), and give me some suggestions on how to do it? Any help will be greatly appreciated.
http://tinyurl.com/y5oppt4p
BR-549
Joined Sep 22, 2013
4,931
What are you doing with the signal, after it is received by an AM radio?
In other words, tell us exactly what you are trying to do. All the details.
DickCappels
Joined Aug 21, 2008
10,661
The easiest way to amplitude modulate your colpitts oscillator is to power the oscillator with the output of the NE555.
If you want to be a little more elegant, you can try something like Charles Wenzel's AM transmitter that uses a Gilbert Cell multiplier to perform the amplitude modulation.
Read about it at: http://www.techlib.com/electronics/amxmit.htm
Patrishayeah
Joined May 30, 2019
15
Hi, so what I want to do in this project is hear a tone in an AM radio when the switch of the transmitter is pressed down, and this way be able to send out morse code. The 555 timer would have an output of about 600 Hz, an audible tone, and the carrier wave would be about 1 MHz (In the link and picture it is less but just so that I have a better overview). This is just a school project, so the transmitter is not supposed to be long range.
Patrishayeah
Joined May 30, 2019
15
Patrishayeah
Joined May 30, 2019
15
Thanks for your reply. Do you mean something like in the picture? I'm pretty sure the modulated carrier wave is not supposed to look like that though. But for amplitude modulation you somehow have to change the amplification of the final transistor, right? My problem is just that I don't know which part of the colpitts oscillator to connect the 555 timer output to, without messing everything up.
wayneh
Joined Sep 9, 2010
18,104
The suggestion by @DickCappels in #6 is the way I'd go. Just turn the carrier on and off with the 555.
wayneh
Joined Sep 9, 2010
18,104
Forgot to add the picture, sorry. Here it is.
That looks OK. I don't understand the simulation output. You need to have the 555 at a much lower frequency than the carrier. Then your simulation should look just like the 555 output, except for, when on, a series of oscillations instead of a steady DC output.
And personally, I'd move the 100Ω resistor on the base of the pass transistor.
Patrishayeah
Joined May 30, 2019
15
Thank you so much! Is this what it's supposed to look like? I changed the carrier frequency to about 1 MHz.Screenshot 2019-05-31 at 5.06.17 PM.png
bertus
Joined Apr 5, 2008
22,925
The pass transistor is mounted the wrong way around.
The collector and emittor should be changed.
Or you should use a PNP transistor in the way you showed.
Bertus
Patrishayeah
Joined May 30, 2019
15
what kind of 555? why bother with transistor and not power oscillator straight from 555 output?
I'll be using the NE555 in astable mode(if that's what you mean). The pass transistor is there to amplify the output of the 555 so it can be modulated properly onto the carrier wave (I think that's supposed to happen, but I'm not sure). I tried doing it without, but the current then flows into the 555 instead of out of it, and no modulation occurs.
Modulating with a square wave will give you a buzzing sound, not a tone.
Your 555 output should have a duty cycle of about 50%. Currently it looks like it is more than 90%.
The 555 output is too large and is almost completely killing the oscillator output. This actually becomes On-Off Keying of the carrier.
You need to pass the output through a capacitor to remove the DC component.
Your circuit is too simple to get good results but you will probably be able to hear it in the receiver.
Zeeus
Joined Apr 17, 2019
616
You must be having fun
