Am I using the right P-channel MOSFET for my high side switch?
Zurn
Joined Mar 4, 2019
122
Hi everyone,
I'm using a microcontroller to control power to my system with a p-channel MOSFET. The uC is an ATTiny85 and the MOSFET is an NDP6020P.
As of now my system is runs between 12 and 16V and everything works fine - however, when I charge the batteries everything jumps up to 24V. Could this be a problem for my MOSFET?
Here's my circuit:
The load is a bunch of things: special uCs, voltage regulators, and some hydrophones.
I've had some problems in the past with misreading MOSFET data sheets, so I figured it would be wise to get a second opinion.
Alec_t
Joined Sep 17, 2013
15,167
The Absolute Maximum Vgs is given as ±8V for that FET. You are using Vgs = 24*10/15 = 16V. Also, maximum rated Vds is only -20V. Houston, I think you have a problem (or two)!
Zurn
Joined Mar 4, 2019
122
Ah yes, I accidentally swapped the resistors in my voltage divider calculation (I did 24*5/15 = 8V). I guess if I swap those resistors around I'll only have one problem.
Now to find a logic controlled P-MOSFET with a Vds of -24V...
Thanks for the input.
djsfantasi
Joined Apr 11, 2010
9,237
Or more. Perhaps one with a Vds of 30V would work? That’s what I used in a 12V system.
