AM/FM Transmitter distortion
Audioguru
Joined Dec 20, 2007
11,248
Super Simple usually means super poor quality (distortion).
Your circuit has nothing like a volume control so the input audio signal level might be too high. The polarity of C6 is backwards.
Your amplifier is missing the very important capacitor in series with a resistor at the output pin 5 of the LM386 to ground.
Is your battery 9V?
Will your crystal oscillator work when its Vcc is from about +3V to about +6V?
Ylli
Joined Nov 13, 2015
1,092
You've got the resistor/capacitor on pin 5 of the LM386 on the 'transmitter' schematic, but these are missing on the 'amplifier' schematic.
You don't say if it is the AM or FM transmitter that sounds distorted. If it is the FM section, then it is most likely too much audio input. If it is the AM section..... well, I don't know of any oscillator modules that will modulate linearly by varying the Vcc.
