Alternator Wiring
francisconqn
Joined Apr 23, 2020
5
Hi, is this alternator wiring right? this is the regulator and the scheme
Regulator
- GND (top and bottom mounts)
- FIELD (cam, from "campo" wich is field in spanish)
- IGN (ignition)
The alternator has a pin that is labeled with "L" and the other is not labeled
So, i connected L to field and the other to GND
Is this ok?
LowQCab
Joined Nov 6, 2012
5,102
It's impossible to say what will work without having
Schematic-Diagrams for both the "Generic-Regulator", and the Alternator.
There are hundreds of ways that this has been done over the years,
"some" of them are "semi-standardized", (maybe),
and some are proprietary to a particular manufacturer.
twohats
Joined Oct 28, 2015
618
Do you have a warning light fitted inside the vehicle, where you can see it when driving?
Many moons ago, Lucas alternators UK, the 'L ' went to the warning light.
Good luck.................
