Alternating fan controller with RC timer and MOSFETs (70 s + 3 s dead-time)
Tammepuu
Joined Aug 23, 2025
6
Hello everyone,
I am looking for a simple and reliable circuit to alternate two fans (FAN A and FAN B) as follows:
• FAN A runs for about 30-70 seconds
• Then a pause of ~3-5 seconds (both fans OFF)
• FAN B runs for about 30-70 seconds
• Then again a pause of 3-5 seconds
• The cycle repeats continuously until power is turned off
Requirements:
- Power supply is 10 V (both fans are 10 V type)
- No relays, no counters, no microcontrollers – only analog solution with RC timing and MOSFET switches
- Each fan should be driven by a MOSFET (low-side switching)
- I would like to have that 3-5second "dead-time" between switching from one fan to the other
- Fan about 1-3 W
- Timing stability 10%
- Or do a digital solution with day timer
ElectricSpidey
Joined Dec 2, 2017
3,358
Yea, I use a circuit in some of my projects that use a 555 and a 4017 with the outputs of the 4017 tied back to the 555 thru diodes that control the timing, that would be perfect for this.
But yea...no counters.
Jerry-Hat-Trick
Joined Aug 31, 2022
849
Your acceptable wide time tolerance should help. Charging a high value capacitor through a large value resistor with the output into a comparator with wide hysteresis, shorting the charged capacitor with a transistor via a lower resistor value might give you the long on/short off sequence. Somehow into a flip flop to select alternate fans. I’d need to sit down with pencil and paper to check this out, but maybe someone can progress this? Or tell me why it won’t work?
ElectricSpidey
Joined Dec 2, 2017
3,358
You are basically describing a 555, but a single F/F can't produce the dead time.
ericgibbs
Joined Jan 29, 2010
21,569
Eric, I added a modification of the 555 timer to get the appx 70 seconds when first powered ON.
Otherwise the first timing cycle was over 110 seconds when tested on the breadboard.
hi sg,
Thanks for the suggestion.;)
I did consider that, but as he stated The cycle repeats continuously until power is turned off
that the longer start up period would not be a problem.
I see now that he is concerned over the initialising circuit power usage, which is so small, when compared to the fan motors.
@Tammepuu What is the power source for the timing circuit??
E
