Alternating blinking leds, pnp transistor not fully off
rphare
Joined Nov 20, 2015
11
Yup. The only remaining problem seems to be that the 555 only goes up to Vcc minus 1.7v when it turns on (as a couple of people pointed out yesterday) so you still need two diodes in series with the LED. No transistor tho.Alt blink leds-simpler.jpg
Audioguru again
Joined Oct 21, 2019
6,826
Your simulator is completely wrong. The output high of an NE555 does not go anywhere near +12V when it has a +12V supply. It goes only to about +10.7. Then the 2N2222 base will go to 10.7V and its emitter will go to only +10V leaving the green LED glowing with 12V - 10V= 2V across it and its resistor. A modern green LED will not glow unless it has at least about 2.8V across it.
Why add old little transistors to the output of a powerful 555? Its output can produce 200mA up and down.
38,786
Try this:
You used the idealizedl 555 model from LTspice (below) for your simulation, which does not represent the exact operation of a real 555.
You need to use a transistor level model, such as the NE555-1, which much more accurately simulates the real device.
eetech00
Joined Jun 8, 2013
4,724
I fixed the sim.
Because you can supply more LED current with the external transistors.
And you can use the CMOS version (TLC555) of the timer if you want.
eT
eetech00
Joined Jun 8, 2013
4,724
Hi C
Thanks....I'm using the right model now.
I corrected post #24
eT
38,786
Note that the green LED current does not go completely to zero due to the offset in the high output voltage from the 555, plus the base-emitter drop from Q2, which further reduces the output voltage.
If you used the CMOS 555, it likely would go to zero.
AlbertHall
Joined Jun 4, 2014
12,653
Even in that simulation the current through the green LED does not fall to zero. There is still about 1mA even when it should be off.
