I've had a toe swell up badly a time or two!Capacitoes
I have a T shirt that says the opposite:
My list is intended to be minimal, Can you propose a black box that I cannot replicate without those?You could add to the list:
.... and so many more.
- negative resistor
- gyrator
- noise generator
- photon capture device
- quantum mechanical tunneling device
- dark matter detector
- quartz crystal
- surface acoustic wave device
Any black box that don't depend on lump-matter assumptions.My list is intended to be minimal, Can you propose a black box that I cannot replicate without those?
Bob
I am talking ideal components here.Any black box that don't depend on lump-matter assumptions.
EM field effects that break lumped-element assumptions:
The change of the magnetic flux in time outside a conductor is NOT zero.
The change of the charge in time inside conducting elements is NOT zero.
Signal timescales of interest are sizable fraction of propagation delay across the lumped element.
https://courses.edx.org/asset-v1:MI...e@asset+block/handouts_6002-L1-oei12-gaps.pdf
I did mention a rectifying device, though I am not certain it is needed.You could add the galena crystal and extrapolate from that. There has been much conjecture and discussion as to whether to include the Diode as a passive device.
That's what I'm talking about too. The electronic circuit theory assumptions for ideal lumped-element components is a sub-set of EM theory. There are things inside a possible passive 'Black Box' that can't be modeled or build using ideal components if effects in the Black Box depend on the EM effects of matter-space geometry. How do you build a passive microwave magatron cavity from electronic components.I am talking ideal components here.
Bob
by Jerry Twomey
