I'm studying an air gapped transformer with E core shape and I want to make a gap of 1 mm.
I can for sure search for two E ferrites with a central gap of 0.5 + 0.5 mm in order to reach the goal.
I'm asking myself what happens if I pick two E ferrites with no gap and I put a separator of 1 mm. Is it the same?
In this case my magnetic flux is interrupted not only in the central branch, but also in the two lateral ones. Should it still be of 1 mm, in order to have the same inductance?
Thank you
Thank you
