So on this. There is ground from the motor that is going though the switch that your turning on and off... That goes to the Relay. Then from the Breaker that goes to the relay where it is connected to 2 pins via the PCB. Then the other one is out. It could be that the relay PCB on the other side is bad where it should be connected to the Coil and what not as to why it don't work... Again. If you took PIN 87 and 30 put them together as I stated in my first post that would be like the switch working and the pump should work...
James
James
