well that's what I thought (ohm's law -- volt ramp on bjt should work vs current source), now the question rephrased: do I need to convert volt to current (optoisolator) for the fact that bjt transistors are current driven, because in spite of ohms law, higher voltage on the bjt doesn't produce any sound... (and I know the theremin works, I tested it with LDRs, just doesn't produce fart, it produces whoowhie)Chillum, remember ohm's law. Voltage and current are a married couple, you can't have one without the other, and increasing one will increase the other if input resistance remains constant. And another thing is to keep in mind that bjt transistors are current driven devices.
I think the farting sound in the video was produced due to poor lighting conditions during testing, which made the optotransistors break their current at a certain frequency and produced clicking noises resembling the sound you want to reproduce.well that's what I thought (ohm's law -- volt ramp on bjt should work vs current source), now the question rephrased: do I need to convert volt to current (optoisolator) for the fact that bjt transistors are current driven, because in spite of ohms law, higher voltage on the bjt doesn't produce any sound... (and I know the theremin works, I tested it with LDRs, just doesn't produce fart, it produces whoowhie)
Yes, of course it can... you don't have to resource to an MCU for this... But I think that @ronv is far more capable than me of solving this nuance quickly.can it be done? or do we venture into microcontrollers?
It does exactly what the breadboard does, click on, click off. :-( PS thing doesn't want to upload the file (I added .txt at the end, cause .wav is not permitted -- still no upload)Chillum, add this line as a SPICE directive to your theremin 05-1.asc file:
.wave C:\theremin.wav 16 44.1k v(line_out_pos) v(line_out_pos)
This should produce the output wav file that you wanted.
To add the line, simply click on the "Aa" icon on the top menu (to the right), and select "SPICE directive" option in the dialog box. Then run the sim afterwards, and your wav file should appear in the root directory of your C drive
we know it's possible, we have documented video proof! what's wrong!? aaarghIt does exactly what the breadboard does, click on, click off. :-( PS thing doesn't want to upload the file (I added .txt at the end, cause .wav is not permitted -- still no upload)
Interesting... it means that we need an additional ramp-down circuit too... like you mentioned a few posts back@cmartinez I think I misunderstood the configuration of the transistors, the one is leading, the other trailing, making the fade of the hand produce something more like what you suggested long ago:View attachment 83828
With all due respect... but will your circuit fart????I think I understand now,
Since you want to make several notes lets forget about the photo transistors and ramps and stuff, and just make several notes.
You can switch in different resistors for R1 to change the frequency.
The sim will output a wave file to the LTSpice main directory.
@ronv very impressive except for the fact that it's a chainsaw sound, the man in the video had fart sound, is there any signal processing we can do on the chainsaw to get it to sound like a fart? or would a ramp down be easier?I think I understand now,
| D | hi from me again. questions about repairing nowadays at all ? | Jobs & Career Advising | 1 | |
again with the constant current generator | PCB Layout , EDA & Simulations | 9 | |
555 question again | General Electronics Chat | 5 | |
What's Old Is New Again | General Electronics Chat | 2 | |
AudioGuru Again | Off-Topic | 24 |
