again with the constant current generator
electronicsenjoyer089
Joined Feb 24, 2025
182
Hello all,
I have made modifications u suggested me to do, now i got on the non inverting input a lower voltage as VREF and i put a resistor of 1k to set the 150uA that has to flow on the capacitor, but what i see is this: across the cap i got is 53mA, i want to have 150uA for 100us, the time there is the positive cycle of the square wave , how and why i could achieve that?
ronsimpson
Joined Oct 7, 2019
4,796
Many comments.
1) I think C1 was not connected on the bottom end.
2) C1 (at time zero) has 3.3V across it. (in my case 5V) There is a way to tell spice to start with 0V across C1. I put a 1,000,000 resistor across C1 to make spice think the cap is discharged at the start.
3) The op-amp you chose is very slow. Its output moves at 0.3V/us typical and maybe as slow at 0.1V/us. Also it takes some time to get started when powered up at time zero. I put it on a separate 5V supply to get rid of the start up time problems.
4) This op-amp does not work if the inputs are near the supply(s) voltage. It does not work at 160mV. It needs more than 1V and more like 2V to work. I put the Vee supply at -3.3V to solve that.
5) I made C1 1000x bigger because the amp could not respond to a small cap charging.
6) I was not certain what Gate voltage was needed so I increased the Vcc supply to 5V. (I see it needs 2.5V) It probably should be a couple of volts above that 2.5V.
Joined Feb 24, 2025
182
Many comments.
I got a bit of questions, sorry if It may be really basic things for u
5) what do u mean the Op amp couldnt respond to a small charging cap? what i need to look into the Op amp as specification? What happens when i put bigger cap? What changes?
Joined Feb 24, 2025
182
Many comments.
but at the end i dont achieve 100uA flowing thought the capacitor for 100us, so i cant know by calculus how much voltage there will be across It, cus there are these spikes etc, consider that im making a f-v converter, so It needs to be precise, the voltage on the cap that i will read with the ADC represents the frequency
ronsimpson
Joined Oct 7, 2019
4,796
The 1uF cap seemed to charge up before the op-amp could respond. This is a very slow amp.
these spikes etc
That MOSFET has 0.0024m ohms of resistance. It is a monster. Pick a much smaller 1 ohm part. That big of a part has large amounts of capacitance. You need a part with low capacitance. I just tried the "RHU003N03" MOSFET which has very little cap. and the spikes are now gone.
Joined Feb 24, 2025
182
oh i got it, a lower rds on in a mosfet means that most likely the mosfet will have a big parasite capacitance, so i choose one with bigger rds on.
ronsimpson
Joined Oct 7, 2019
4,796
for choosing the op amp i need one that is quick enough to follow up right?
I would choose one that is much faster on the Volts/U second. But after the first pulse it seem to be OK.
Green trace is V1 signal. Red trace is the Gate drive.
Here I show the rise and fall time only.
Here is zoomed in showing rise time. At 400uS the signal goes high, Current starts up at 401uS and makes it by 402.5uS.
I think if you used a amp with 2 to 4 V/uS this delay will be 1/10 as much. (blue trace is current)
Joined Feb 24, 2025
182
Ok i understood thanks :D , i basically completed all the stages for my f-v converter
