AG7100 Converter
clark.kent156
Joined Aug 17, 2019
52
OK, so you can desolder the .1 headers on there and use the pads any way you want, or, you can get some Dupont female header connectors and make cables that will plug in.
This kit would allow you to make up two cables that match: https://www.amazon.com/Proster-Crimping-Connectors-0-1-1-0mm²-Connector/dp/B07GS1Z3M3/
Hi. So I did desolder those to use the pads. For test of the booster, I am using a walwart wall plug, 12v 700mA with alligator clips soldered on the wires. Multimeter shows 11.95v from the plug. But I'm not getting any reading on the output. I am looking up more documentation to see what I am doing wrong.
