Affordable Analog Mutiplexer IC
iimagine
Joined Dec 20, 2010
512
I'm looking for an analog multiplexer IC that functions like the Harris HA-2400 but at an affordable/cheap price. Does anyone know of such IC?
iimagine
Joined Dec 20, 2010
512
basically i just wanted to be able to switch audio inputs using an MPU, what sort of criteria am i looking for?
34,880
For starters:
1) Number of channels (x2 for stereo)
2) Frequency range (20-20kHz assuming audio)
3) Voltage range (±12V, for example)
4) Serial or parallel control of channel select
5) Package style, thru-hole DIP or SMT
iimagine
Joined Dec 20, 2010
512
1) Channels: >= 4
2) Freq range: audio (20-20kHz)
3) Voltage range: <= ±12V
4) Serial
5) Package style: thru-hole
Thanks.
Lestraveled
Joined May 19, 2014
1,946
The HA-2400 is not just a multiplexer, it has four independent op-amps, one on each channel, and then a 1 of 4 selector. Do you not need the built in amplifiers that the HA-2400 has?
If you just need an analog switch, then look at the DG441.
iimagine
Joined Dec 20, 2010
512
The built in amplifiers of the HA-2400 is a nice feature and I guess thats why it is expensive; I just need an analog switch with a built in decoder. Thanks for recommending the DG441
iimagine
Joined Dec 20, 2010
512
Why do you need such a high signal voltage?
I dont need a high signal voltage; I should have put VCC Voltage range <= ±12V; Signal voltages are just at line level;
What I'm looking for is an audio signal selector IC/circuit (CD/TAPE...ect) that can be selected/switched from a Microprocessor
alfacliff
Joined Dec 13, 2013
2,458
the 4066 is a quad bilateral switch, it has no decoder. the 4051 is a 1 of 8 multiplexer / demultiplexer that will switch line level signals wither direction with binary selection.
Lestraveled
Joined May 19, 2014
1,946
The OP wants a +- 12 volt part which the DG441 will do. The CD4066 and CD4051 will not support +-12 volts because they are single supply 15 volt(max) parts.
GopherT
Joined Nov 23, 2012
8,009
The OP said, less than 12 volts. And then cal airfield that he wanted line level audio in post 10.
I stand corrected, 4066 is not correct. 4051 should work.
iimagine
Joined Dec 20, 2010
512
Thank you everyone for your recommendations. The 4051 is a winner for me. I just ordered 10 PC for a total of $3.88 (shipping included!) Cant beat that.
GopherT
Joined Nov 23, 2012
8,009
Was that an eBay purchase or is there a US supplier with low shipping rates? Please let us know where you found those prices if not eBay.
Cheers
