advice please on "eFuse" concept
daz E
Joined Nov 7, 2017
47
Could you please suggest / point out any "gotchas" with the concept I have for a 10amp eFuse / circuit breaker , for automotive application. Ideas on component models/parts also welcome.
A very simple design to protect motorcycles (12Vdc) by tripping a load at 10amp.
wayneh
Joined Sep 9, 2010
18,157
I don’t see the need for the Schmitt driver, if you use a genuine comparator instead of an opamp, although that may be fine also. You’d definitely want some hysteresis to prevent chatter.
I don’t understand what you’re trying to do, turn the load off if it takes more than 10A? I’m pretty sure you could accomplish the latch-off by just feeding back to the comparator inputs.
daz E
Joined Nov 7, 2017
47
Yes, quite right. My bad.
I shall use a non inverting comparator and set LTP and UTP ... What ratio would you recommend as Beta??
I want to shut the whole circuit down when Iload reaches ~10a. Feedback wouldn't accomplish this.i could drive a latched relay but Id prefer a solid state solution.
Alec_t
Joined Sep 17, 2013
15,156
With a 12V supply you won't get more than 12V out of the comparator!
You will need to find a high-side comparator: most are low-side. Google for "high side current sense" to identify a suitable IC.
This article may help.
daz E
Joined Nov 7, 2017
47
As per OP, 12v is all i seek.
I have looked at HS sense ICs, but they overcomplicate the application introducing unnecessary logic and diagnostics
Im going for a simple quad HS comparator each output driving a MOSFET. Some ICs already have both, just a case of finding/searching 100,000s !!
daz E
Joined Nov 7, 2017
47
Guys ,
I intend to build a box similar in fit,form and function to the PDM60 or Denali Power Hub or ClearWater monitor. All variants on the idea of motorcycle accessory wiring through a solid state box which provides internal busbar to battery V+ , individual fused circuits for upto "n" accessories with CB function. I simply intend to replicate this but I feel 4 circuits in addition to factory fitted accessories is more than ample. A quad Comparator would suffice.
These OEM boxes are £150+ and totally overpriced.
Aside from all this, this is a project for me , I want to do it. Its a hobby. Why would I buy OEM therefore !
So, what I really require is help with the concept, maybe a few IC suggestions, or circuit snippets. Meanwhile I continue to scour the massive databases of ICs !!
EDIT: Revised block diagram attached.
daz E
Joined Nov 7, 2017
47
In fact, Linear make an IC just for the job and with that magic 10A max. If I were to assemble a board with x4 of these circuits,...? Could it be that easy? I suppose a quad equiv would be even better all round - anyone know of such a device??
shortbus
Joined Sep 30, 2009
10,049
Before spending too much time on that chip, you may want to figure out if it will withstand the very noisy electrical system in a automotive/motorcycle environment. They are far different than a normal electronic environment. Many chips made for vehicles have internal ways to prevent problems you may not for see.
daz E
Joined Nov 7, 2017
47
Yes, I am aware of ESD , load dumps, transients etc consideration.
if you have any practical offerings, say for example a specific device model/reference, now that would be really really useful .
I would really like to move this thread forward beyond the "beware of this" , "think about that", and very simply seek some practical advice and constructive ideas and suggestions as to the OP.
Thank you all the same and I await the model / devices you have in mind !;)
