I have this lit Halloween display piece and one small bulb does work inside one of the lanterns. There are four lanterns on tree branches that light. There are another five small lights on the other parts of the tree. It uses 3 AA batteries or a 4.5 v ac adapter. The bulbs in the lantern are about the size of a pen tip with two wires per bulb.
Do you know what type of bulb this is?
https://imgur.com/PLWt6Wz
https://imgur.com/X6eS9ay
Do you think that this area could be removed with a heat gun? It seems like that would be the only way they could assemble it in the first place. The only other way I see would be the wire going out the bottom of the lantern and they solder the bulb, then pull the wire back through branch/piece?
https://imgur.com/a/NpYMGUR
Another question I have is that the bulbs are clear, but when lit they look the color of each lantern. Can these small clear bulbs be a colored bulb, or am I seeing the reflection of the lantern color on the bulb?
Thanks
Thanks
