Advice on epoxy coated PCB
STREETRIDER1105
Joined Nov 21, 2019
19
What is the best way to test and desoder components on a board that is coated in a epoxy
Mod: lightened the image.
jpanhalt
Joined Jan 18, 2008
10,078
The solder resist is epoxy and covers traces, but not solder joints. Are you sure the solder joints are covered with epoxy, or if covered with anything, maybe it is an acrylic "conformal" coating. That is usually very thin. Test probes will usually penetrate it, and usually it can be soldered through as the acrylic vaporizes. I would give that a try first. If that fails, a fiberglass scratch brush can be used to remove the coatings. Those brushes are available at any shop that sells auto refinishing materials.
Here's a link: https://www.amazon.com/Scratch-Brush-Fiberglass-Colors-vary/dp/B0019V18D2/ref=sr_1_5?keywords=scratch+brush&qid=1575528931&sr=8-5
EDIT: If it is ordinary, air-dry acrylic, then lacquer thinner, MEK, or acetone will remove it from larger areas.
