Advice On Buy Wire Stripping Machine
HalfMadDad
Joined Jun 10, 2016
43
Hi Everyone
I have lots of hand held manual wire strippers here but I was thinking about buying something that would make life a bit easier. I only need to strip small gauge wires like 24 to 18.
Could you recommend something that would be faster than hand held tools?
Thanks for reading-Patrick
HalfMadDad
Joined Jun 10, 2016
43
Thanks MaxHeadRoom,
Thanks Yaakov, heh he, yes, I am telling the family they will walk from now :)
The heated version should work fine, I am just using regular stuff.
Ya’akov
Joined Jan 27, 2019
10,294
Thanks MaxHeadRoom,
Those thermal strippers have been around a long time. Just make sure what you buy has the right capacity for your application. Also I have had great success with this: filtered smoke absorber and would recommend it for this and soldering.
Ya’akov
Joined Jan 27, 2019
10,294
Thanks Yaakov, I do all of my soldering in a large insulated shed in my back yard :)
A smoke absorber uses an activated charcoal filter to trap the nasty particulates.
The nice thing about this one it=s it takes up no bench space and can be moved close to the work when needed, then out of the way.
