Advice from soldering experts
kareem101
Joined Jan 5, 2015
5
I have this part spu0410LR5H-Qb ,, that has the soldering pads under it,, I want to solder it manually "unfortunately" :( ,, any help about how to do it ?
spinnaker
Joined Oct 29, 2009
7,830
This is not a trivial procedure. You will need a stencil and use the reflow process. Check section 3.5 of the Deign Guide.
Below is an image from the Design Guide. Looks like you have more problems than just soldering. There are lots and lots of other design issues to consider too. Have you checked with places like Sparkfun to see if there is one with a breakout board?
A gasket must be made of acoustically opaque materi
al that prevents sound from passing through
it. The material must seal completely to the case
and to the microphone or PCB. In a stack-up
tolerance analysis, the gasket must form a compress
ion fit in worst case (large gap) conditions,
while compressing enough in small gap conditions to
avoid bulges in the product case or the
walls of the acoustic path. Good acoustic sealing
prevents echo, noise, and frequency response
problems that can result from resonant air volumes
inside the product housing and from alternate
paths to the mic port-hole.
The manufacturability of the mic-gasket-case assemb
ly must also be considered. The assembly
process must be designed to reliably align the hole
s in the gasket to the holes in the case and mic
or PCB in volume production. Side-port or end-port
gasket designs are more difficult to
assemble, since the required gasket compression for
ce is often parallel to the surface of the
microphone and perpendicular to the usual case comp
ression force as shown in figure (a) below.
These types of gaskets can have problems with leaks
during assembly, but a well-designed
assembly process or a gasket design such as that sh
own in (b) can form good seals.
nerdegutta
Joined Dec 15, 2009
2,689
I see six pads. How about using a veroboard, some jumperwires and a 1x6 pin header?
Solder the wires to the pads, and to the pin header. The you'll make your own breakout-board. :)
cmartinez
Joined Jan 17, 2007
8,773
It looks to me like you can't just solder this thing down. It needs to be mounted properly so it functions as designed.
You may be right. But if it's firmly glued to the PCB, all the user would need to do is build a proper acoustic box around it. Then again, there's only one way to know if he did things correctly...
SLK001
Joined Nov 29, 2011
1,549
Apply solder to the pads on the PCB. Make sure that the solder height on each pad is as close to equal as you can get. I sight the height by looking from the edge across the solder. Tin the pads on the device with solder, then wick all the excess solder off using solder wick. Apply paste solder flux to both the PCB pads and the part pads. Using a heat gun, flow the solder on the PCB, then place the part on the melted solder. Continue heating the part and the board until the part is grabbed by the solder. You can tell that the part is grabbbed by gently nudging the part. It will move with the nudge, then return to its proper position.
Be careful. You can easily add too much heat and damage both the part and the PCB.
All this assumes that you have a proper PCB with correct pads and solder mask waiting for you to place the part. Without a good board, you probably won't succeed in soldering the part.
kareem101
Joined Jan 5, 2015
5
OK thanks all for ur replay, I am not worried about its performance, Right now I am leaving hanging in the air and soldered its pads via wrap wire. And it is working great, the guy that designed The analog circuit for this thing did a great Job, it is sensing the ultrasonic 80Khz meter away.
I am more worried about the soldering, I will try as SLK001 suggested, although this may damage the mic, the damn thing is 260 celsius degree max for 20-40 sec, If it got damaged, I will glue it as cmartinez suggested and wire from pads to PCB. will let u know the results.
Thanks.
SLK001
Joined Nov 29, 2011
1,549
Thanks.
If you let the solder flow on the pads, then place the part on the molten solder, your time exposure for the part will be less than 10 seconds (using regular 60/40 solder). Once you do this a few times, you will actually see when the part is "grabbed" by the solder and you can stop the hot air a few seconds later. With a difficult part like this to place, it should be the first part placed and soldered.
