First off, Arduinos aren't PICs. I think what you mean to say is that you want to learn about microcontrollers, of which, PICs and ATMEGA(the chips the Arduino bootloader is loaded onto - depending on type of Arduino, of course) are members.Hi, I want to learn how to use PIC's and am leaning towards Adruino.
Unfortunately, automotive modifications are against the rules here, so I don't think we can help you there...For my first project I want to build a PWM controller that will have the capability to control two 30 amp fans for my truck. Any suggestions of Adruino kit I should start with?
Can I ask why this site is so against using or developing electronics for use with vehicles? What if he would have simply said ..."to power two 30 Amp fans"? No one would be the wiser. What if I want to modify or develop some electronics to work with a bicycle. Does this then become a motorbike (aka a vehicle) meaning it becomes a "banned" topic?In case you want to learn about microcontrollers, we can do something about it.
But using your project to interfere in any degree with your truck in strictly prohibited in this site.
Please re-phrase your question, following the above suggestions, and we 'll see what we can do.
That is a good place to start, I should know, it's the exact one I started with!I was thinking PIC...I was looking at PIC12F683
I suppose you could, but PIC microcontrollers are generally(for hobby use) programmed with a Pickit, typically either the Pickit 2, or Pickit 3....So can I use the Arduino to program and play with it?
To be fair, there is not a microcontroller that cannot utilize the Arduino accessories, there may not be a ready-made set of libraries to use it, but it can be done.You can also get alot of cool accessories for the Arduino that's not available for the PIC. I make my own PIC accessories, but it's a pain in the butt to do so.
| M | Analogue SPDT Circuit | Analog & Mixed-Signal Design | 3 | |
| L | DIY Adruino Check of Circuit. Your thoughts? | General Electronics Chat | 2 | |
| K | adruino board with servo motor | General Electronics Chat | 5 | |
| K | adruino board mega2650 | Microcontrollers | 1 | |
| T | Adruino and ARM Processor interfacing via JTAG | Microcontrollers | 0 |
