Adjustable low DC voltage trigger signal relay or SSR
AACCSS
Joined Dec 1, 2020
Is there a relay or SSR that the trigger voltage is adjustable between 0.5vdc and 4.5vdc.
I want to use voltage from a automotive gauge to trigger a relay or SSR to activate a buzzer to warn the operator.
This would be for oil psi, oil temp, ECT, Trans temp, etc. etc.
eetech00
Joined Jun 8, 2013
4,724
Not a relay. But you can use a comparator or opamp to drive an SSR.
The trigger would be adjusted via a reference voltage to the comparator.
