Adjustable duty cycle for a 555 oscillator?
JulesP
Joined Dec 7, 2018
458
Hi there,
I have a simple 555 signal generator (circuit attached) that, using a series of adjustable trimmers, I can get an output of a variety of frequencies, e.g. 200Hz, at around 12V.
However, the output waveform (see attached) has a duty cycle of about 60% but I would like this to be adjustable from 30-60%.
Is that doable with some straightforward modification to the circuit?
Jules
JulesP
Joined Dec 7, 2018
458
Thanks for that Sam. With that design can I also go above 50% if needed?
Has the design been withdrawn for some reason?
Julian
JulesP
Joined Dec 7, 2018
458
Lol. Sorry I saw the SamR at the bottom of your reply.
I have read the relevant section and it seems straightforward but what diode spec is Ok?
I have plenty of IN4007s so would the be fine?
Jules Verne
35,322
If you would like to control frequency and duty cycle independently you can follow the 555-timer with a monostable multi-vibrator circuit such as 74HC123, CD4098, CD14528 or CD14538.
