Adjustable delay switching of two relays alternately
adjeiwaf
Joined Mar 4, 2015
2
I need to alternately switch two dry contacts /relays with variable time delays say 15mins or 20mins intervals .Think a 555 timer would work but will it be adjustable and have these two outputs?
#12
One timer chip can not count both 15 minutes and 20 minutes at the same time. It will be adjustable if you build it to be adjustable. A 555 timer is really stretching to do 20 minutes. Better try a CD4020 counter chip.
adjeiwaf
Joined Mar 4, 2015
2
kindly help e with cd 4020typicadiagram l
Reloadron
Joined Jan 15, 2015
7,949
You can as mentioned build your own circuit around a CD4020 timer chip and a Google of CD4020 Timer Circuits will yield dozens of circuits or as Mike mentioned, work from the data sheet. If this is for a commercial or industrial application another option is to simply buy a timer relay and a Google of Timer Relays will also bring up dozens of solutions which are plug and play. Since I have no clue as to your location I can't suggest manufacturers or model numbers of plug and play solutions.
Ron
#12
I was designing circuits before the Internet was invented. I had to read the datasheet and teach myself how to connect chips. I assumed everybody did that. AmIright?
mcgyvr
Joined Oct 15, 2009
5,394
I was designing circuits before the Internet was invented. I had to read the datasheet and teach myself how to connect chips. I assumed everybody did that. Am I right?
No just old :p
Sadly.. The datasheet is usually the last thing people look at now a days..
Way too many forums/tutorials/youtube videos/blog posts,etc.. about EVERYTHING...
#12
Let me clarify: Before the internet was invented, did everybody have to read the datasheet and teach themselves how to connect IC's?
Reloadron
Joined Jan 15, 2015
7,949
Before the Internet was invented I had to find the data sheet. If the data sheet wasn't in the department library then I took a walk to the main company library. The real bitch was before the copy machine was available.
Ron
