Adding USB-powered bluetooth dongle to internals of a 1980s boombox
Inksea
Joined Jan 25, 2024
Hey everyone - didn't know where else to start on this one. So I have an old 1980s era boombox (tape deck, AM/FM, aux in), and I'd love to cram in a cheap bluetooth dongle (like this) that draws power from the boombox's AC connection, and the headphone out routes directly to the aux port. That way, when the boombox is connected to power, the bluetooth comes online and is available through the aux channel.
How would I connect the bluetooth dongle to the boombox's AC line, so I don't blow up the boombox or ignite the bluetooth module or something?
tonyStewart
Joined May 8, 2012
238
You will need a 5V 3 terminal regulator and some place inside that has 7 to 12+ Vdc only when turned on to drive the regulator. Use a TO-220 type just in case it gets too warm. I expect the BT dongle is not a high power load. You can also add a jack inside to hide the cable wired to Aux in. There ought to be a battery compartment with lots of room around the speakers, then hot glue in place so it won't rattle. If you don't have a cheap DMM, get one.
Inksea
Joined Jan 25, 2024
Something like this?
