adding antenna to clock radio
lokeycmos
Joined Apr 3, 2009
431
i need to solder on an external FM antenna to my clock radio. i attached some pics. there is a ferrite rod for am. but i cant see anything for fm. could someone please point out where i would solder the antenna to the board? TY
mcgyvr
Joined Oct 15, 2009
5,394
Looks to me that its the trace at the top of the board of picture 2. The one connected to the pad labeled "FM"
Audioguru
Joined Dec 20, 2007
11,248
The short trace on the pcb is too short for an antenna for the FM broadcast band. It should be near 80cm long like a long whip or like the power cord.
lokeycmos
Joined Apr 3, 2009
431
does anyone know of a good site for schematics? it a GE 7-4813B. i did figure out that the FM antenna is coupled to the power cord. instead of the power transformer having 2 primary and 2 secondary leads, it has 6 secondary leads. some how the antenna is coupled to it throught the swirl traces. hoping i can find a schem. ty
Wendy
Joined Mar 24, 2008
23,810
You could try a 5' piece of wire with 1' run parallel to the power cord to see if it helps. You don't always need to connect an antenna directly to a circuit.
If it works, but is still too weak, try 8', as that approaches the resonant length of 88Mhz.
Audioguru
Joined Dec 20, 2007
11,248
The very cheap radio will be overloaded by strong local stations if its antenna is too good. Then the stongest stations will be all across the dial like my cheap Sony Walkman FM stereo radio (it has a local-distant switch that attenuates the antenna in the local position).
The datasheet for Toshiba's TA2003 radio IC has recommended simple schematics of radios that use it.
trader007
Joined Feb 27, 2010
249
This is a bit of a thread bump, but my question directly relates to this topic.
If you have a cheap radio (mine is a armband radio), and it uses the headphone cord as the antenna (like cellphones do), is there a way to add an external antenna?
I have a reason for putting a tiny fm tuner in a custom boombox... but I dont know where I should hook up an external antenna.
