ADC Output
Luckyguide
Joined Feb 28, 2025
35
I am designing a circuit around the ADC08L060, it says in its datasheet that the output will be 2.6V typically. My FPGA GPIO pins only see active high from 3.3V. Will this ADC output be able to reach that value? Nowhere on the datasheet was i able to find that.
Luckyguide
Joined Feb 28, 2025
35
Thanks for the response, the max input voltage for AC input is about 3.3 volts. I am driving the input AC signal with an Op-Amp that is connected to a 12V power supply(can't change that). In case there would ever be a scenario in which the op-amp sends a signal higher than 3.3V, then i would like to clamp it. But diodes have either too high capacitances, and schottky diodes don't clamp at 3.3V. Any suggestions?
Irving
Joined Jan 30, 2016
5,121
You don't need to clamp it, there are diodes in the package that will clamp the analog input to GND-0.3v and VA+0.3v. What you need to do is limit any current flow in/out of the pin to prevent chip overheating with a series resistor. In the case of the analog input that resistor will create a low-pass filter with the input capacitance so its value will be important, What is your maximum expected input frequency? Can you show your input amplifier arrangement.
Note the comment in the datasheet:
See also the example Fig 32 in the data sheet.
