ADC diode low temperature problem
ilginsarican
Joined Jul 13, 2017
147
This is the ADC schematic.
I've tested this circuit at -40C.
At - 40C, the ADC value of read by MCU is 5V.
Second picture is about B340A diode forward voltage-forward current graphic
The Operating Temperature Range of diode is -55 / +155.
I think that at -40C, D35 does not forward biased but I dont know why:( .
But At - 40C, the ADC value of read by MCU is 5V, if so how D36 forward biased?
AlbertHall
Joined Jun 4, 2014
12,653
The LM324 has an input bias current of between 45uA and 100uA and this current is in a direction which tends to pull the inputs positive.
This current will pull pin 5 of the LM324 positive and this will reverse bias D36 and so the pin voltage will rise up towards the positve supply voltage and hence the high voltage reading.
Bordodynov
Joined May 20, 2015
3,431
You're clearly lying. This operating amplifier in this circuit cannot be output at the 5 V output. You need to pass the same current through the diodes to obtain thermal stability.
AlbertHall, The LM324 has an input bias current of between 45nA and 100nA.
ilginsarican
Joined Jul 13, 2017
147
"At - 40C, the ADC value of read by MCU is 5V." I meant approximately 5V, you can think it is like pull up(+5V)
ilginsarican
Joined Jul 13, 2017
147
According to datasheet of diode, it can operate at -55C.
I dont understand the relationship between temperature.
In datasheet of LM324, the input bias current is Temperature Compensated.
Is this problem about bias current?
kubeek
Joined Sep 20, 2005
5,796
can you please explain what is the purpose of the circuit, and where did you get those 1.5kH (!) inductors to test the circuit with?
AlbertHall
Joined Jun 4, 2014
12,653
If the forward voltages of the diodes are supposed to cancel each other then they should have the same current. You can achieve this by connecting a resistor from D36 cathode to gnd with a value equal to R2 plus the DC resistance of F6. This will reduce the current through R2 so you might want ro reduce R8, perhaps 470Ω.
Bordodynov
Joined May 20, 2015
3,431
This is a feature of LTspice's work. When I was drawing the diagram, I just put in a diode. Then I entered the diode selection menu and chose Schottky's diode. The symbol changed. I didn't want to look for the same diode again, so I copied the name of Schottky's diode and put it in place of the name D. If I enter the diode selection menu, the symbol will change to the Schottky diode symbol after closing. In addition, the diode of the shots is also a diode! And there is no error.
Bordodynov
Joined May 20, 2015
3,431
Note the difference in the value of the high level. My operating amplifier model is made at the transistor level. And as you know, the voltage of the Base Emitter increases when the temperature drops. Therefore, with my model, the output voltage is lower.
ilginsarican
Joined Jul 13, 2017
147
I face this problem only when the ambient temperature lower than -20C.
