Active ballancer IC for Li-ion
BrMisha
Joined Aug 13, 2022
32
Hi!
Currently, I'm using the BQ76940 for my BMS 30S but it isn't enough efficiency so now I'm looking for an active balancing solution.
What I want:
  1. Digital interface
  2. Cheap))
In the worst case, I will use BQ76940 + active balancer IC for every cell.
Could you recommend me some IC?
bassbindevil
Joined Jan 23, 2014
922
I bookmarked this a while back; cost was about $3 per bank.
http://www.afdhalatifftan.com/2017/06/low-cost-active-battery-balancer.html
No smarts, though.
There's this DIY BMS, but doesn't have active balancing as far as I can tell:
https://github.com/stuartpittaway/diyBMSv4
Maybe it's not too hard to adapt to active balancing?
My hands-on experience with active balancing is limited to buying (but not yet using) a board marked "Active Battery Cell Balancing" JW-5C1.2A. (5C for up to 5 cells (banks), 1.2A for 1.2 amps balancing current.) Like this one:
https://www.beyondlogic.org/review-...ive-equalizer-balancer-energy-transfer-board/
which reveals that the chip is an ETA3000
Data sheet here:
https://web.archive.org/web/2020013...n.com/upload/201905/09/201905091810050738.pdf
