ronsimpson
- Joined Oct 7, 2019
- 4,829
If VCC=5V +/- 3% then you need to correct for that.It is right if VCC=5v
Last time I used an ADC that used VCC and GND as reference(s). That way if VCC was off the ADC was also off by that exact amount.
It microcontroller and ACS712 share the same supply, and the microcontroller's A/D positive reference is the positive supply, then the A/D should read 0x8000 left-justified to 16 bits when there is no current (give or take the 4% error)It is right if VCC=5v
But I agree, I should have stated VCC*0.5 where VCC is the ACS712 supply voltage.
