thatoneguy
- Joined Feb 19, 2009
- 6,359
I'd suggest reading both the article and references on Wikipedia Crystals as Oscillators
There is a ton of info out there, including what sort of cut/shear you have for a crystal, and using it as a series or parallel oscillator, depending on the type you have.
Normally, you'd just solder in the crystal with the right number on it, but you may have oscillators, which are 4 pin rectangular packages, opposed to the long oval crystal only type package.
It's a few hours worth of reading, or less if you are familiar with the basics, but required if you are looking for accuracy. Just because there is a crystal involved doesn't mean it is a great oscillator.
