I want to make a USB charger which can act as charger as well as can can also help smart phone or different wireless sensor like Wireless Temperature sensor to access with ESP8266.
For accessing a smartphone :
I want to install different drivers and set the function through some application securely by using USB connection only. I don't want any modification in application through wireless connection between application and ESP8266
Advice on this will be a great help.
For Wireless sensor Temperature access:
After the setup done with smartphone, I will connect the wireless modem which will receive the values of wireless sensor and it will perform its function
Any advice on circuit which will help to make the USB work as charger as well as data transfer will be a great help.
