I'm having trouble locating a device that in my mind should be something commonly available in industry. Maybe I'm using the wrong types of search terms, so hopefully you can help or point me in the right direction.
I've got a component in my system that requires 110VAC, however, the system is meant to be used around the world, so places where wall power can vary from 110VAC to 220VAC, as well as in frequency. I've contacted the manufacturer and they told me the component will work as long as the voltage is around 110VAC, and that it won't work with 220VAC, but it can handle 50-60Hz. I am unable to place a manual toggle switch on the system where the operator can select an expected input, and in turn, have the power routed through a step down transformer if its for 220V.
So is there such a device that automatically does this detection with an electronic output? Alot of my searches turn up "voltage detectors" with visual meters. The only other searches which turned up anything useful are circuit schematics using discrete electronic components (resistors, caps, ICs, etc). I don't have the luxury of spinning a board or breadboard, this is for an commercial system.
So I'm hoping for some nicely packaged DIN-mount type module which detected the voltage level. If it had internal switches that routed each voltage range a certain way that would be even better, but even if it just had a discrete output or something I can use to control a relay to a transformer that helps.
Thanks for any help!
