AC question
Sincewhen08
Joined Jun 9, 2022
Hey all - -newbie here. I have a question about AC. I understand the idea changing polarity. What about changing direction? Does AC come from ground then from its positive? If that makes any sense - if I have a circuit, an AC power supply with a positive and negative, does the current flow reverse directions? What about high voltage transmission lines? What I am asking I think is how "far" can AC travel?
Sidebar - am I right in assuming a capacitor is there to make up for the switch in polarity direction to keep a smooth current going?
Thanks!
MaxHeadRoom
Joined Jul 18, 2013
30,654
AC = Alternating current, as in alternating/change in direction of current every half cycle.!
A capacitor across an AC power supply/source can pass a high degree of current when the C value is relatively high.
e.g. It is used to conduct AC current to a 1ph motor start winding, it also provides a phase shift in the winding.
As to power lines, they use very high voltage in order to maintain low current, now if the distance is great, DC transmission is preferred.
k1ng 1337
Joined Sep 11, 2020
1,038
Signal polarity is referencing to the direction current will flow in a conductor. Consider an AC signal connected to a diode, since the diode will only conduct in one direction (ignoring leakage), half the wave will be clipped. If you reverse the diode, the other half will be clipped. If there is no diode, the current will "move" back and forth assuming there is an equal impedance in both directions as well as congruent positive and negative voltage portions of the signal. The principal of reactance becomes important because the voltage / current relationship of inductors and capacitors are no longer linear like a resistor. This expands to the concept of real and reactive power as some arrangements can capitalize on the current already "present" instead of having been dissipated as heat so less real power is consumed.
Please note this is an intuitive response and will not replace a mathematical analysis.
Sincewhen08
Joined Jun 9, 2022
Ok makes some sense - so let’s say for example any electronic device in my home. The AC travels from the pole in the item (not concerned about polarity) and then all the way back to the transformer on the street or to the input to my house?
k1ng 1337
Joined Sep 11, 2020
1,038
Can you rephrase your question?
Thanks!
Yes, the AC current (electrons in wires) changes direction in the wire but it only travels a very tiny distance, then reverses, so the average current movement is zero from transformer to house is zero. What moves from transformer to house is electrical energy/power. The physical movement of current is usually not much of a factor in actual electrical energy transfer.
Sincewhen08
Joined Jun 9, 2022
Ok - i think I get that. I thought it travelled an incredible amount of distance in a short time.
So if it’s reversing back and forth, even a short distance, how does it keep “moving” forward? Like how does it complete a circuit if it seems it doesn’t really move? I know this is incredibly basic. I respect your patience with me.
k1ng 1337
Joined Sep 11, 2020
1,038
So we can say the electrons act as one big Newton's Cradle coupling momentum from one adjacent electron to the next?
No, electrons don't transfer the electrical energy in the circuit. When electrons transfer energy, things usually get hot at those spots. For a heater element that's good, for a power line that's bad so we size the wire to reduce electron energy coupling to a some satisfactory amount to reduce I/R losses.
k1ng 1337
Joined Sep 11, 2020
1,038
What is responsible for the transfer of energy?
ApacheKid
Joined Jan 12, 2015
1,762
Thanks!
This is insightful, certainly worth watching carefully:
Have you written any literature on the subject?
No, there are tons of good websites, EE and physics books that go into the centuries old details. I don''t have the patience or desire to be a teacher.
https://books.google.com/books?id=U...rs (current) are the energy carriers.&f=false
The strange thing is there is nothing in modern circuit theory that says the charge carriers (current) are the transmission energy carriers. Most people get the idea from bad analogies, not formal training. Current is an important part of the equation as a system and things like AC current are a hell of a lot more intuitive when you put current in its proper place within the energy transfer equation.
https://learn.sparkfun.com/tutorials/what-is-electricity/all
