AC Power source
uppi_777
Joined Feb 26, 2018
42
i am using AC Power supply and i have given 5.4V (but its shown as Vrms)and frequency 60Hz the current is automatically calculated by the device.
1,i want to manually calculate the current many i know how do i get 0.01A (if given 5.4V and 60Hz)
2.Difference b/w Vrms and V
30,419
You need to know the impedance of the load for a 60Hz sinewave.
V the designation for volts.
Vrms indicates the RMS value of the voltage (which is √2 * Vpk of a sinusoidal where Vpk is the peak voltage).
Vdc would indicate the voltage is DC.
Alec_t
Joined Sep 17, 2013
13,039
Whatever you're driving with the AC supply is the load, so the load's impedance won't be in the supply's datasheet.
12,678
If that is an AC supply that you are using, then that displayed current, 0.01 A is a measured value, not a calculated value. I am not aware of power supplies that calculate current. They may calculate watts and even VAR and power factor, but current and voltage are measured values.
12,678
The display image shown in post #1 appears to be on a regulated adjustable AC power supply with internal metering. It is evidently supplying some sort of load.
Normally sine wave AC voltages are assumed to be expressed in RMS volts, because that is most convenient for calculating power, and also the relationship to peak voltage is well understood.
But given only the voltage and frequency with no hint at the load, I see no way to calculate the current.
So it will be useful to get an explanation of what the TS is actually seeking to discover.
12,678
Here is the data sheet of my AC Power source
This is a nice laboratory type of AC supply. What is missing from the description is any mention of measurement accuracy or resolution. And I disagree! The current is measured, it is not calculated. To calculate current one needs both voltage and resistance. The calculation is very simple, but understand I (current) = E (voltage)/R(resistance in ohms).
