Experts! Shout for help again!
I'm trying to build an AC power/energy meter for some project of mine. I'm using the ACS712 Hall Effect current sensor for this project due to its compact size and very high output linearity. I'm using the 30A version of this sensor. I use the ADS1115 16bit ADC to read the output from ACS712 and process it in the code.
I'm building this on an ESP8266 microprocessor board using Arduino IDE. Below is my code for calculating the power. As a starting point, I've taken the code for now from:
https://www.instructables.com/id/Arduino-Energy-Meter-V20/
For testing, I'm using a 200W filament bulb as load.C:// Arduino Energy Meter V2.0 // This code is for This code is for Wemos(ESP8266) based Energy monitoring Device // This code is a modified version of sample code from https://github.com/pieman64/ESPecoMon // Last updated on 30.05.2018 #include <Wire.h> #include <Adafruit_ADS1015.h> #include <ESP8266WiFi.h> #include <ESP8266HTTPClient.h> Adafruit_ADS1115 ads(0x48); /* Use this for the 16-bit version */ #define SERIAL_BAUD 115200 int ledPower = 12; // ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 3mV (default) // ads.setGain(GAIN_ONE); // 1x gain +/- 4.096V 1 bit = 2mV // ads.setGain(GAIN_TWO); // 2x gain +/- 2.048V 1 bit = 1mV // ads.setGain(GAIN_FOUR); // 4x gain +/- 1.024V 1 bit = 0.5mV // ads.setGain(GAIN_EIGHT); // 8x gain +/- 0.512V 1 bit = 0.25mV // ads.setGain(GAIN_SIXTEEN); // 16x gain +/- 0.256V 1 bit = 0.125mV unsigned int Sensitivity = 66; // 185mV/A for 5A, 100 mV/A for 20A and 66mV/A for 30A Module float Vpp = 0; // peak-peak voltage float Vrms = 0; // rms voltage float Irms = 0; // rms current float Supply_Voltage = 247.0; // reading from DMM float Vcc = 5.0; // ADC reference voltage // voltage at 5V pin float power = 0; // power in watt float Wh =0 ; // Energy in kWh unsigned long last_time =0; unsigned long current_time =0; unsigned long interval = 100; unsigned int calibration = 12; // V2 slider calibrates this unsigned int pF = 85; // Power Factor default 95 void getACS712() { // for AC Vpp = getVPP(); Vrms = (Vpp/2.0) *0.707; Vrms = Vrms - (calibration / 10000.0); // calibtrate to zero with slider Irms = (Vrms * 1000)/Sensitivity ; if((Irms > -0.015) && (Irms < 0.008)){ // remove low end chatter Irms = 0.0; } power= (Supply_Voltage * Irms) * (pF / 100.0); last_time = current_time; current_time = millis(); Wh = Wh+ power *(( current_time -last_time) /3600000.0) ; // calculating energy in Watt-Hour Serial.print("Irms: "); Serial.print(String(Irms, 3)); Serial.println(" A"); Serial.print("Power: "); Serial.print(String(power, 3)); Serial.print(" W"); Serial.print("\t Energy Unit(s) (KWh): "); Serial.println(String((Wh/1000), 4)); } float getVPP() { int16_t adc1; float result; int readValue; int maxValue = 0; int minValue = 32768; uint32_t start_time = millis(); while((millis()-start_time) < 950) //read every 0.95 Sec { readValue = ads.readADC_SingleEnded(1); if (readValue > maxValue) { maxValue = readValue; } if (readValue < minValue) { minValue = readValue; } } result = ((maxValue - minValue) * Vcc) / 32768.0; Serial.print("\nVp-p: "); Serial.println(String(result, 3)); return result; } void setup() { Serial.begin(115200); Serial.println("\n Rebooted"); Serial.begin(SERIAL_BAUD); while(!Serial) {} // Wait Wire.begin(D3,D4); //Changed defaults to match ESP8266 pin connections: 23 - SDA, 24 - SCL ads.begin(); WiFi.begin("Tulsani", "homenetwork"); Serial.print("Connecting"); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(); Serial.print("Connected, IP address: "); Serial.println(WiFi.localIP()); pinMode(ledPower,OUTPUT); } void loop() { getACS712(); delay (2000); }
Issue that I'm facing is:
- When I check the current on my DMM, it shows approx 0.8A of current drawn
- Output of the ESP8266, using the above code, shows me a current drawn of approx 1A
AC voltage seen on my DMM is approx 245V (I know its on the higher side. It should be around 230V, but what to do ... its India).
Can someone help me understand/identify where am I going wrong or where the code is going wrong? Would be of immense help!
Regards,
Deepak
Sir May I know why you made of as default bcoz of varies device to device kindly tell me sirAre the below any good to get a baseline/crude figure for PF? I assume that this will show me the PF for the load that is connected to it?
https://www.amazon.in/Techno-Single-Phase-Power-Factor/dp/B00Z16DNT8
https://www.amazon.in/Caldipree-Dig...1535037593&sr=1-8&keywords=power+factor+meter
Link to old Thread.
https://forum.allaboutcircuits.com/...-calculation-using-acs712.150636/post-1299207
