You're describing DC output, not AC.That should have been, it is '12V AC 800mA 9.6VA' the sign beside the 12V is a straight horizontal line with 3 dashes below, so AC not DC.
Now I am totally confused. According to the adaptor that was supplied (black and white image), and re-supplied it is an AC/AC Adaptor.
It can work if there is a bridge rectifier supplying the LEDs it will simply pass the DC. That's just luck, though. A different sort of supply would not have worked.Now I am totally confused. According to the adaptor that was supplied (black and white image), and re-supplied it is an AC/AC Adaptor.
The plaslode adaptor (second yellow image) is AC/DC, but it lit up the lights.
But the paslode adaptor lit up all the lights.
But if the lights are AC, am I correct in saying that this should not have happened?
This is from the manual, it is where I have circled it in blue, but it is internal.It is 23:27 here in the UK, I'll take and post a picture tomorrow.
If the lights are LEDs, they only emit light when forward biased. If reverse biased sufficiently, the junctions will breakdown. Whether that will damage them depends on the voltage and current involved.But if the lights are AC, am I correct in saying that this should not have happened?
So it really needs to be an AC / AC adaptor similar to the one supplied.If the lights are LEDs, they only emit light when forward biased. If reverse biased sufficiently, the junctions will breakdown. Whether that will damage them depends on the voltage and current involved.
We generally think of AC adaptors as converting AC to DC. When an adapter says it's AC to AC, the input and output are AC and a transformer will typically be involved because generating a sinewave power output isn't easy.
We can't say for certain without knowing how the LEDs are being driven.So it really needs to be an AC / AC adaptor similar to the one supplied.
Make sure you get the correct connector size and polarity. In my area, 2.1mmx5.5mm female are most common. They're easy to confuse with 2.5mmx5.5mm if you're not used to sizing them by eye.This company sells this one, and others, and for £12.50 plus postage I don't mind having a go.
Nope. That's DC. not AC.the sign beside the 12V is a straight horizontal line with 3 dashes below, so AC not DC.
I'll have to cut the connector off, the original adaptors have a a 'one way' plug on them, One terminal is round, the other square.We can't say for certain without knowing how the LEDs are being driven.
| M | USB to Serial Adaptor issues | Analog & Mixed-Signal Design | 2 | |
| D | The pressure sensor signal modulation board keeps experiencing zero-point pressure drift. How should I adjust it? | Sensor Design & Implementation | 5 |
