about the circuit reverse protection by P-fet
LAOADAM
Joined Nov 21, 2018
956
Hi all.
the picture shown the circuit, that has a zener to protect P-fet.
question:
1. is this circuit suite for a 5V supply unit or only for higher power unit like 15V of the drawing used to?
2. how to calculate the voltage of D1?
Thanks.
Adam
LAOADAM
Joined Nov 21, 2018
956
For a 5V source you need a logic-level type MOSFET (Vgs(th) max ≤2V).
The MOSFET you show needs a Vgs of 10V to be fully on.
thank you. seems not easy to find p-fet logic-level type MOSFET.
The VP2206 got: Vgs(th): -1.0 ~ -3.5, is it OK?
AO3401 got: -0.5v ~-1.3v better?
38,598
They both should work but the AO3401 is better.
Look at the Vgs voltage used for the Rds(on) in the spec sheet.
If it's measured at a Vgs of 5V or less, then it's a logic-level type MOSFET (below for VP2206):
Which to use depends upon the maximum load current and how much voltage drop you can tolerate at that current.
