Because the AOZ7648 is a synchronous rectifierwhy the secondary part don't have diode?how to rectify?
It's part of the RCD suppression circuit to prevent overshoot of the primary voltage.2.what is the function of the capacitor near the resistor of the primary side?
sorry I don't quite understand of your reply. I need more detailed explanation.Because the AOZ7648 is a synchronous rectifier
http://www.aosmd.com/res/data_sheets/AOZ7648QI-06.pdf
It has some power pins labelled SOURCE and DRAIN, so they connect to an internal MOSFET which acts as a synchronous rectifier.1.I think AOZ7648 is an ic that takes secondary circuit outputs and give feedback signals of TXN and TXP. how it works as a synchronous rectifier?
See2. how's the capacitor do to make a RCD surprenssion?
I think:
