About stability of buck converter
wang1234567
Joined Dec 24, 2017
Hi, everyone.
I am doing a project about buck converter.
I want to inject a stimulus signal to observe the deviation of the component and estimate the stability of the whole system.
example: observe the ESR variation of the output capacitor, if the ESR value becomes larger, the system would be unstable?
or another component parameter variation influences the system stability.
But I don't know how to implement on my circuit.
Thanks for the reply!
wang1234567
Joined Dec 24, 2017
It's just in the conception stage now.
After that, I will turn it into an integrated circuit.
Briefly speaking, I want to inject a stimulus signal into the circuit and observe the response.
Therefore I can know the health status of switch mode power supply, and then predict the remaining useful life of SMPS.
But I have no idea how could I do.:(
Thanks for the reply.
38,909
One way is to inject a small signal through a high value resistor in series with a capacitor into a low impedance point in the feedback loop (such as the minus input of an op amp).
Injecting a sinewave frequency sweep and measuring the output phase and amplitude will give a Bode plot to check the loop stability.
Injecting a step or pulse will check the transient response for any significant ringing, which also is a measure of loop stability.
wang1234567
Joined Dec 24, 2017
I am still thinking not sure, maybe the voltage or current stimulus signal.
Take this as example: http://ieeexplore.ieee.org/document/5351978/
The author injects a white noise as stimulus signal and uses identification method to measure the diagnostic indicator.
But I want to do it more easily.
Inject a stimulus signal then observe the response characteristics.
Maybe the characteristics behavior is slew rate, settling time, overshoot, etc..
