About diodes
ntetlow
Joined Jul 12, 2019
71
Aattached are two views of an ab amp. each one has a diode in the input section facing in a different direction, The left one is plated so that there is only input to the pnp transistor and the right so that there is only input to the npn transistor. This is all as expected.
My question is, why are the two transistors facing down (the ones under the 10k resistors) letting current flow, since they are supposed to block negative current. The question is probably naive but please could someone enlighten me?
MrAl
Joined Jun 17, 2014
13,864
Something does not look right there.
