AA4 6 pin ic.. I could not find this ic and its data please help me..
Syed2025
Joined Sep 25, 2021
6
I have have touch panal pcb board of 5 pin each five pin is connected to the 6 pin ic one of them is burnt out number written on ic is AA4 I could not find this ic and its data please help me..
Papabravo
Joined Feb 24, 2006
22,115
It is not optocoupler its very small size ic..
Size has absolutely NOTHING to do with function. Why would you think this is the case? Do you have a schematic for the board?
ETA: The SMD marking database suggests a Torex Semiconductor voltage regulator. Multiple pieces on the board suggest this apparent match may not be valid, unless you have some reason to think otherwise.
AA4​
XC6114B635MR​
Torex Semiconductor
SOT-25
Voltage detector IC
3.5V±2%, ±Reset PPO, Wt=1.6s, Rdt=25ms
Syed2025
Joined Sep 25, 2021
6
No this is not XC6114B635MR .
XC6114B635MR is 5 pin microcontrollar rest ic ..but my ic is 6 pin and taking input from touch panel of 5pin. each pin of touch panel connected to individual AA4 .IMG20240316233824.jpg
