Somebody suggested an applause meter.You can customize it as you wish, Amps, Volts, Ohms !
Or even for a Scientology E-Meter for Auditing!!!
Unqualified explanation as fodder for bigger brains:Interesting asymmetrical compression at the ends.
ak
Might indicate it has a diode rectifier, which would make the start of reading very non-linear.Interesting asymmetrical compression at the ends.
No, it's definitely an iron vane meter; I popped the hood just to see if I could find any manufacturer's IDMight indicate it has a diode rectifier, which would make the start of reading very non-linear.
