a timer that goes logic high or low every 15mins ( using tiny85 chip)
timtim1234
Joined Nov 30, 2023
246
Here is a ARDUINO SKETCH that has more ttiny chips programmed into it. This is to fix a bricked chip using a HVP programmer
I don't think the other sketch that in the link on how to build a HVP programmer has this???
Code:
// AVR High-voltage Serial Fuse Reprogrammer
// Adapted from code and design by Paul Willoughby 03/20/2010
// http://www.rickety.us/2010/03/arduino-avr-high-voltage-serial-programmer/
// Fuse Calc:
// http://www.engbedded.com/fusecalc/
#define RST 13 // Output to level shifter for !RESET from transistor
#define SCI 12 // Target Clock Input
#define SDO 11 // Target Data Output
#define SII 10 // Target Instruction Input
#define SDI 9 // Target Data Input
#define VCC 8 // Target VCC
#define HFUSE 0x747C
#define LFUSE 0x646C
#define EFUSE 0x666E
// Define ATTiny series signatures
#define ATTINY13 0x9007 // L: 0x6A, H: 0xFF 8 pin
#define ATTINY24 0x910B // L: 0x62, H: 0xDF, E: 0xFF 14 pin
#define ATTINY25 0x9108 // L: 0x62, H: 0xDF, E: 0xFF 8 pin
#define ATTINY44 0x9207 // L: 0x62, H: 0xDF, E: 0xFFF 14 pin
#define ATTINY45 0x9206 // L: 0x62, H: 0xDF, E: 0xFF 8 pin
#define ATTINY84 0x930C // L: 0x62, H: 0xDF, E: 0xFFF 14 pin
#define ATTINY85 0x930B // L: 0x62, H: 0xDF, E: 0xFF 8 pin
void setup() {
pinMode(VCC, OUTPUT);
pinMode(RST, OUTPUT);
pinMode(SDI, OUTPUT);
pinMode(SII, OUTPUT);
pinMode(SCI, OUTPUT);
pinMode(SDO, OUTPUT); // Configured as input when in programming mode
digitalWrite(RST, HIGH); // Level shifter is inverting, this shuts off 12V
Serial.begin(19200);
Serial.println("Code is modified by Rik. Visit riktronics.wordpress.com and electronics-lab.com for more projects");
Serial.println("-------------------------------------------------------------------------------------------------");
Serial.println("Enter any character to start process..");}
void loop() {
if (Serial.available() > 0) {
Serial.read();
pinMode(SDO, OUTPUT); // Set SDO to output
digitalWrite(SDI, LOW);
digitalWrite(SII, LOW);
digitalWrite(SDO, LOW);
digitalWrite(RST, HIGH); // 12v Off
digitalWrite(VCC, HIGH); // Vcc On
delayMicroseconds(20);
digitalWrite(RST, LOW); // 12v On
delayMicroseconds(10);
pinMode(SDO, INPUT); // Set SDO to input
delayMicroseconds(300);
unsigned int sig = readSignature();
Serial.println("Reading signature from connected ATtiny......");
Serial.println("Reading complete..");
Serial.print("Signature is: ");
Serial.println(sig, HEX);
readFuses();
if (sig == ATTINY13) {
Serial.println("The ATtiny is detected as ATtiny13/ATtiny13A..");
Serial.print("LFUSE: ");
writeFuse(LFUSE, 0x6A);
Serial.print("HFUSE: ");
writeFuse(HFUSE, 0xFF);
Serial.println("");
} else if (sig == ATTINY24 || sig == ATTINY44 || sig == ATTINY84 ||
sig == ATTINY25 || sig == ATTINY45 || sig == ATTINY85) {
Serial.println("The ATtiny is detected as ");
if(sig == ATTINY24) Serial.println("ATTINY24..");
else if(sig == ATTINY44) Serial.println("ATTINY44..");
else if(sig == ATTINY84) Serial.println("ATTINY84..");
else if(sig == ATTINY25) Serial.println("ATTINY25..");
else if(sig == ATTINY45) Serial.println("ATTINY45..");
else if(sig == ATTINY85) Serial.println("ATTINY85..");
writeFuse(LFUSE, 0x62);
writeFuse(HFUSE, 0xDF);
writeFuse(EFUSE, 0xFF);
Serial.println("Fuses will be read again to check if it's changed successfully..");
readFuses();
digitalWrite(SCI, LOW);
digitalWrite(VCC, LOW); // Vcc Off
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("");
byte shiftOut (byte val1, byte val2) {
int inBits = 0;
//Wait until SDO goes high
while (!digitalRead(SDO))
unsigned int dout = (unsigned int) val1 << 2;
unsigned int iout = (unsigned int) val2 << 2;
for (int ii = 10; ii >= 0; ii--) {
digitalWrite(SDI, !!(dout & (1 << ii)));
digitalWrite(SII, !!(iout & (1 << ii)));
inBits <<= 1; inBits |= digitalRead(SDO);
digitalWrite(SCI, HIGH);
return inBits >> 2;
void writeFuse (unsigned int fuse, byte val) {
Serial.println("Writing correct fuse settings to ATtiny.......");
shiftOut(0x40, 0x4C);
shiftOut( val, 0x2C);
shiftOut(0x00, (byte) (fuse >> 8));
shiftOut(0x00, (byte) fuse);
Serial.println("Writing complete..");
void readFuses () {
Serial.println("Reading fuse settings from connected ATtiny.......");
byte val;
shiftOut(0x04, 0x4C); // LFuse
shiftOut(0x00, 0x68);
val = shiftOut(0x00, 0x6C);
Serial.print("LFuse: ");
Serial.print(val, HEX);
shiftOut(0x04, 0x4C); // HFuse
shiftOut(0x00, 0x7A);
val = shiftOut(0x00, 0x7E);
Serial.print(", HFuse: ");
shiftOut(0x04, 0x4C); // EFuse
shiftOut(0x00, 0x6A);
val = shiftOut(0x00, 0x6E);
Serial.print(", EFuse: ");
Serial.println(val, HEX);
unsigned int readSignature () {
unsigned int sig = 0;
byte val;
for (int ii = 1; ii < 3; ii++) {
shiftOut(0x08, 0x4C);
shiftOut( ii, 0x0C);
sig = (sig << 8) + val;
return sig;
be80be
Joined Jul 5, 2008
2,395
There basically the same thing I only posted for the 85 I have one that doses a bunch of avrs chips
Code:
HVRescue Simple 2015-09-17 suitable for breadboard
instructables.com/id/HV-Rescue-Simple
Modified from HVRescue_Shield Arduino sketch 3/15/11 2.12 for use with the HV Rescue Shield
by Jeff Keyzer  mightyohm.com/hvrescue2
Enhancements/mods by dmjlambert
HV control inverted to work with 12V battery switched
  with a transistor as in the older Jeff Keyzer sketch
  and common HV programmer sketches for ATtiny.
Changed baud rate to 115200
Moved data0 from D0 to A1 to keep from conflicting with serial port
  and to work better with boards such as CH340G Nano
Changed direct port manipulation of portD to indivial Arduino pins
Changed default fuse values to ATmega328P typical values
Removed run button
Removed ASKMODE
Briefly go into programming mode just for the task at hand
Accept a variety of number formats, hex, decimal, binary, upper/lower case
Made tolerant of any line ending for serial input or no line ending at all
Made compatible with most Arduinos such as Uno, Leonardo, Mega2560,
  Pro Mini, Nano
Consolidated/simplified/organized into sections
Incorporated new user interface and menu with these commands:
1 2 3 set mode
L set low fuse value
H set high fuse value
X set ext fuse value
B or U set typical L H and X fuse values to factory blank 328 or Uno
W write fuses
R read fuses
? or any invalid character display info
Attempted to preserve non-interactive setting.  Although the sketch
ends up at an interactive menu prompt, the work it does before getting
to the interactive state can be used.  Plug in a target chip and press
the Arduino reset button to program or read the chip fuses, then unplug
the chip and plug in another and reset to repeat.
The HVPP routines are based on those described in the ATmega48/88/168 datasheet rev.
2545M-AVR-09/07, pg. 290-297 and the ATtiny2313 datasheet rev. 2543I-AVR-04/06 pg. 165-176.
The HVSP routines are based on the ATtiny25/45/85 and 13A datasheets (ATtiny25/45/85 2586M–AVR–07/10 pg. 159-165,
ATtiny13A 8126E-AVR-7/10 pg. 109-116).
GNU General Public License gnu.org/licenses
// User defined settings
#define  DEFAULTMODE  ATMEGA  // If running in non-interactive mode, you need to set this to ATMEGA, TINY2313, or HVSP.
#define  INTERACTIVE  1       // Set this to 0 to disable interactive mode
#define  BURN_EFUSE   1       // Set this to 1 to enable burning extended fuse byte
#define  BAUD         115200  // Serial port rate at which to talk to PC
#define SERIALTIMEOUT 3000    // Amount of time to wait for complete input if CR/LF off
// If interactive mode is off, these fuse settings are used instead of user prompted values
#define  LFUSE        0x62  // default for ATmega328P per datasheet p282-284 0x62 UNO=0xFF
#define  HFUSE        0xD9  // default for ATmega328P per datasheet p282-284 0xD9 UNO=0xDE Duemilanove328=0xDA
#define  EFUSE        0xFF  // default for ATmega328P per datasheet p282-284 0xFF UNO=0x05(effective FD)
// default low fuse  for ATtiny85 per datasheet p148-149 0x62 digispark=0xF1
// default high fuse for ATtiny85 per datasheet p148-149 0xDF digispark=0xD5
// default ext fuse  for ATtiny85 per datasheet p148-149 0xFF digispark=0xFE
// default low fuse  for ATtiny2313 per datasheet p159-160 0x64
// default high fuse for ATtiny2313 per datasheet p159-160 0xDF
// default ext fuse  for ATtiny2313 per datasheet p159-160 0xFF
// Pin Assignments
#define DATA0 A1
#define DATA1 1
#define DATA2 2
#define DATA3 3
#define DATA4 4
#define DATA5 5
#define DATA6 6
#define DATA7 7
#define  VCC     12
#define  RDY     13    // RDY/!BSY signal from target
#define  OE      11
#define  WR      10
#define  BS1     A2
#define  XA0     8
#define  XA1     A4
#define  RST     A0    // 12V to target reset enable (!12V_EN)
#define  XTAL1   A3
#define  PAGELM  A5
#define  BS2M    9
// Pin assignment adjustments for Tiny
#define  PAGELT  BS1 // PAGEL is set to same pin as BS1 for ATtiny2313
#define  BS2T    XA1 // BS2 is set to same pin as XA1 for ATtiny2313
// Pin assignments for HVSP mode
#define  SCI    BS1
#define  SDO    RDY
#define  SII    XA0
#define  SDI    XA1
// Serial instructions for HVSP mode
// Based on the ATtiny85 datasheet Table 20-16 pg. 163-165.
// These instructions don't contain the necessary zero padding, which is added later.
// LFUSE
#define HVSP_READ_LFUSE_DATA     B00000100  // For the commands we are interested in
#define HVSP_READ_LFUSE_INSTR1   B01001100  // only the 1st instruction contains a fixed data packet.
#define HVSP_READ_LFUSE_INSTR2   B01101000  // Instructions 2-3 have data = all zeros.
#define HVSP_READ_LFUSE_INSTR3   B01101100
#define HVSP_WRITE_LFUSE_DATA    B01000000  // For the write instructions, the data contents
#define HVSP_WRITE_LFUSE_INSTR1  B01001100  // for instruction 2 are the desired fuse bits.
#define HVSP_WRITE_LFUSE_INSTR2  B00101100  // Instructions 3-4 have data = all zeros.
#define HVSP_WRITE_LFUSE_INSTR3  B01100100
#define HVSP_WRITE_LFUSE_INSTR4  B01101100
// HFUSE
#define HVSP_READ_HFUSE_DATA     B00000100
#define HVSP_READ_HFUSE_INSTR1   B01001100
#define HVSP_READ_HFUSE_INSTR2   B01111010
#define HVSP_READ_HFUSE_INSTR3   B01111110
#define HVSP_WRITE_HFUSE_DATA    B01000000
#define HVSP_WRITE_HFUSE_INSTR1  B01001100
#define HVSP_WRITE_HFUSE_INSTR2  B00101100
#define HVSP_WRITE_HFUSE_INSTR3  B01110100
#define HVSP_WRITE_HFUSE_INSTR4  B01111100
// EFUSE
// Note: not all ATtiny's have an EFUSE
#define HVSP_READ_EFUSE_DATA     B00000100
#define HVSP_READ_EFUSE_INSTR1   B01001100
#define HVSP_READ_EFUSE_INSTR2   B01101010
#define HVSP_READ_EFUSE_INSTR3   B01101110
#define HVSP_WRITE_EFUSE_DATA    B01000000
#define HVSP_WRITE_EFUSE_INSTR1  B01001100
#define HVSP_WRITE_EFUSE_INSTR2  B00101100
#define HVSP_WRITE_EFUSE_INSTR3  B01100110
#define HVSP_WRITE_EFUSE_INSTR4  B01101110
// Internal definitions
enum modelist { ATMEGA, TINY2313, HVSP };
enum fusesel { LFUSE_SEL, HFUSE_SEL, EFUSE_SEL };
// Global variables
byte mode = DEFAULTMODE;  // programming mode
String inputString = "";         // a string to hold incoming data
boolean stringComplete = false;  // whether the string is complete
long val1;
byte base = 0;
byte lfuse = LFUSE;
byte hfuse = HFUSE;
byte efuse = EFUSE;
// These pin assignments change depending on which chip is being programmed,
// so they are put into variables
byte PAGEL = PAGELM;
byte BS2 = BS2M;
void setup() { // run once, when the sketch starts
  // reserve bytes for the inputString
  inputString.reserve(26);
  // Set up control lines for HV parallel programming
  // clear digital pins 0-7
  digitalWrite(DATA0, 0);
  digitalWrite(DATA1, 0);
  digitalWrite(DATA2, 0);
  digitalWrite(DATA3, 0);
  digitalWrite(DATA4, 0);
  digitalWrite(DATA5, 0);
  digitalWrite(DATA6, 0);
  digitalWrite(DATA7, 0);
  //  set digital pins 0-7 as inputs for now
  pinMode(DATA0, INPUT);
  pinMode(DATA1, INPUT);
  pinMode(DATA2, INPUT);
  pinMode(DATA3, INPUT);
  pinMode(DATA4, INPUT);
  pinMode(DATA5, INPUT);
  pinMode(DATA6, INPUT);
  pinMode(DATA7, INPUT);
  pinMode(RDY, INPUT);
  pinMode(OE, OUTPUT);
  pinMode(WR, OUTPUT);
  pinMode(BS1, OUTPUT);
  pinMode(XA0, OUTPUT);
  pinMode(XA1, OUTPUT);
  pinMode(PAGEL, OUTPUT);
  pinMode(RST, OUTPUT);  // enable signal for DC-DC converter that generates +12V !RESET
  pinMode(BS2, OUTPUT);
  pinMode(XTAL1, OUTPUT);
  // Initialize output pins as needed
  digitalWrite(RST, HIGH);  // Turn off 12V step-up converter (non-inverting, unlike original circuit)
  Serial.begin(BAUD);  // Open serial port
  delay(50);
#if defined __AVR_ATmega32U4__ && INTERACTIVE == 1
  // if Leonardo or similar wait for serial monitor connection
  while (!Serial) ;
#endif
  Serial.println(F("\n\nReset\n"));
  Serial.println(F(__FILE__));
  Serial.println();
}  // end of setup
void loop() {  // run over and over again
  byte read_hfuse, read_lfuse, read_efuse;  // fuses read from target for verify
  // variable to store what to do next, options
  // 0=display choices
  // 1=prompt for a command
  // 2=do nothing and expect further input
  // 3=read fuses from target AVR
  // 4=write fuses to target AVR
  static int doNext = 0;
#if (INTERACTIVE == 0)
  if (doNext == 0) {
    doNext = 4;  //non-interactive, just write the fuses, change to 3 to just read the fuses
#endif
  if (doNext == 0) {  // 0=display choices
    Serial.print("Selected mode: ");
    switch (mode) {
      case ATMEGA:
        Serial.println("ATMEGA");
        break;
      case TINY2313:
        Serial.println("ATtiny2313");
        break;
      case HVSP:
        Serial.println("ATtiny/HVSP");
        break;
    Serial.println(F("Typical fuse values:"));
    Serial.println(F("          blank ATmega328P    UNO     Duemilanove328"));
    Serial.println(F("                    L 0x62   L 0xFF   L 0xFF"));
    Serial.println(F("                    H 0xD9   H 0xDE   H 0xDA"));
    Serial.println(F("                    X 0xFF   X 0xFD   X 0xFD"));
    Serial.print(F("\nProposed Low Fuse  "));
    Serial.print(F("hex: "));
    printHex(lfuse);
    Serial.print(F("  bin: "));
    printBits(lfuse);
    Serial.println();
    Serial.print(F("Proposed High Fuse "));
    printHex(hfuse);
    printBits(hfuse);
    Serial.println();
    Serial.print(F("Proposed Ext Fuse  "));
    printHex(efuse);
    printBits(efuse);
    Serial.println();
    Serial.println(F("\nCommands:"));
    Serial.println(F("1 select mode ATmegaXX8 28-pin"));
    Serial.println(F("2 select mode ATtiny2313"));
    Serial.println(F("3 select mode ATtiny 8-pin / HVSP"));
    Serial.println(F("L, H, or X followed by a number changes the proposed fuse"));
    Serial.println(F("B or U changes the proposed fuses to Blank or Uno"));
    Serial.println(F("R reads the current fuses from the target AVR"));
    Serial.println(F("W writes the proposed fuses to the target AVR"));
    Serial.println(F("Number format accepted is hex in the form FF or 0xFF"));
    Serial.println(F("    or decimal in the form NUM255"));
    Serial.println(F("    or binary in the form BIN11111111"));
    Serial.println(F("Upper or lower case is acceptable"));
    doNext = 1;
  if (doNext == 1) { // 1=prompt for a command
    Serial.println(F("\nEnter a command:"));
    doNext = 2;
  // 2=do nothing and expect further input, no routine for it, just skip through the loop
  if (doNext == 3) {  // 3=read fuses from target AVR
    Serial.end();
    delay(50);
    // Initialize pins to enter programming mode
    digitalWrite(PAGEL, LOW);
    digitalWrite(XA1, LOW);
    digitalWrite(XA0, LOW);
    digitalWrite(BS1, LOW);
    digitalWrite(BS2, LOW);
    digitalWrite(WR, LOW);  // ATtiny2313 needs this to be low to enter programming mode, ATmega doesn't care
    digitalWrite(OE, LOW);
    if (mode == HVSP) {
      digitalWrite(SDI, LOW);  // set necessary pin values to enter programming mode
      pinMode(SDO, OUTPUT);    // SDO is same as RDY pin
      digitalWrite(SDO, LOW);  // needs to be low to enter programming mode
    // Enter programming mode
    digitalWrite(VCC, HIGH);  // Apply VCC to start programming process
    delayMicroseconds(80);
    digitalWrite(RST, LOW);   // Apply 12V to !RESET thru transistor
    if (mode == HVSP) {
      // reset SDO after short delay, longer leads to logic contention because target sets SDO high after entering programming mode
      delayMicroseconds(1);   // datasheet says 10us, 1us is needed to avoid drive contention on SDO
      pinMode(SDO, INPUT);    // set to input to avoid logic contention
    delayMicroseconds(10);  // Give lots of time for part to enter programming mode
    digitalWrite(OE, HIGH);
    digitalWrite(WR, HIGH);   // Now that we're in programming mode we can disable !WR
    delay(1);
    // Now in programming mode until RST is set HIGH again to remove 12V
    if (mode == HVSP) {
      HVSP_read(HVSP_READ_LFUSE_DATA, HVSP_READ_LFUSE_INSTR1);
      HVSP_read(0x00, HVSP_READ_LFUSE_INSTR2);
      read_lfuse = HVSP_read(0x00, HVSP_READ_LFUSE_INSTR3);
      HVSP_read(HVSP_READ_HFUSE_DATA, HVSP_READ_HFUSE_INSTR1);
      HVSP_read(0x00, HVSP_READ_HFUSE_INSTR2);
      read_hfuse = HVSP_read(0x00, HVSP_READ_HFUSE_INSTR3);
#if (BURN_EFUSE == 1)
      HVSP_read(HVSP_READ_EFUSE_DATA, HVSP_READ_EFUSE_INSTR1);
      HVSP_read(0x00, HVSP_READ_EFUSE_INSTR2);
      read_efuse = HVSP_read(0x00, HVSP_READ_EFUSE_INSTR3);
#endif
    } else {
      // Get current fuse settings stored on target device
      read_lfuse = fuse_read(LFUSE_SEL);
      read_hfuse = fuse_read(HFUSE_SEL);
      read_efuse = fuse_read(EFUSE_SEL);
#endif
    // done, disable outputs
    digitalWrite(RST, HIGH);  // exit programming mode
    delay(1);
    // Open serial port again to print fuse values
    Serial.begin(BAUD);
    delay(50);
    Serial.println();
    Serial.print(F("Read Low Fuse  "));
    printHex(read_lfuse);
    printBits(read_lfuse);
    Serial.println();
    Serial.print(F("Read High Fuse "));
    printHex(read_hfuse);
    printBits(read_hfuse);
    Serial.println();
    Serial.print(F("Read Ext Fuse  "));
    printHex(read_efuse);
    printBits(read_efuse);
    Serial.println();
#endif
    Serial.println();
    doNext = 1;
  } // end of doNext3 read sequence
  if (doNext == 4) {  // 4=write fuses to target AVR
    // This business with TXC0 is required because Arduino doesn't give us a means to tell if a serial
    // transmission is complete before we move on and do other things.  If we don't wait for TXC0 to be reset,
    // I found that sometimes the 1st fuse burn would fail.  It turns out that DATA1 (which doubles as Arduino serial
    // TX) was still toggling by the time the 1st XTAL strobe latches the fuse program command.  Bad news.
#ifndef __AVR_ATmega32U4__
    UCSR0A |= _BV(TXC0);  // Reset serial transmit complete flag (need to do this manually because TX interrupts aren't used by Arduino)
#endif
    Serial.println(F("Burning fuses"));
    while (!(UCSR0A & _BV(TXC0))); // Wait for serial transmission to complete before burning fuses!
#endif
    Serial.end();    // We're done with serial comms (for now) so disable UART
    delay(50);
    if (mode == HVSP) {
    digitalWrite(RST, LOW);   // Apply 12V to !RESET thru level shifter
    if (mode == HVSP) {
    delay(1);
    // Now burn desired fuses
    // How we do this depends on which mode we're in
    if (mode == HVSP) {
      HVSP_write(HVSP_WRITE_LFUSE_DATA, HVSP_WRITE_LFUSE_INSTR1);
      HVSP_write(lfuse, HVSP_WRITE_LFUSE_INSTR2);
      HVSP_write(0x00, HVSP_WRITE_LFUSE_INSTR3);
      HVSP_write(0x00, HVSP_WRITE_LFUSE_INSTR4);
      while (digitalRead(SDO) == LOW); // wait until burn is done
      HVSP_write(HVSP_WRITE_HFUSE_DATA, HVSP_WRITE_HFUSE_INSTR1);
      HVSP_write(hfuse, HVSP_WRITE_HFUSE_INSTR2);
      HVSP_write(0x00, HVSP_WRITE_HFUSE_INSTR3);
      HVSP_write(0x00, HVSP_WRITE_HFUSE_INSTR4);
      HVSP_write(HVSP_WRITE_EFUSE_DATA, HVSP_WRITE_EFUSE_INSTR1);
      HVSP_write(efuse, HVSP_WRITE_EFUSE_INSTR2);
      HVSP_write(0x00, HVSP_WRITE_EFUSE_INSTR3);
      HVSP_write(0x00, HVSP_WRITE_EFUSE_INSTR4);
#endif
    } else {
      //delay(10);
      // First, program HFUSE
      fuse_burn(hfuse, HFUSE_SEL);
      // Now, program LFUSE
      fuse_burn(lfuse, LFUSE_SEL);
      // Lastly, program EFUSE
      fuse_burn(efuse, EFUSE_SEL);
#endif
    Serial.begin(BAUD);  // open serial port
    delay(50);
    Serial.println();  // flush out any garbage data on the link left over from programming
    Serial.println(F("Burn complete"));
    Serial.println();
    delay(1);
    doNext = 3;  // read the fuses next
  } //end of doNext4 read sequence
  // handle a string which came in via Serial and decide what to do next based on the input
  if (stringComplete) {
    evalString();
    if (inputString == "1") {
      Serial.println(F("ATMEGA mode"));
      PAGEL = PAGELM;
      BS2 = BS2M;
      mode = ATMEGA;
      doNext = 1;
      base = 99;
    else if (inputString == "2") {
      Serial.println(F("ATtiny2313 mode"));
      // reassign PAGEL and BS2 to their combined counterparts on the '2313
      PAGEL = PAGELT;
      BS2 = BS2T;
      mode = TINY2313;
      doNext = 1;
      base = 99;
    else if (inputString == "3") {
      Serial.println(F("ATtiny/HVSP mode"));
      PAGEL = PAGELM;
      BS2 = BS2M;
      mode = HVSP;
      doNext = 1;
      base = 99;
    else if (inputString == "B") {
      Serial.println(F("Set Proposed Blank 328 Fuses"));
      lfuse = LFUSE;
      hfuse = HFUSE;
      efuse = EFUSE;
      doNext = 0;
      base = 99;
    else if (inputString == "U") {
      Serial.println(F("Set Proposed Uno Fuses"));
      lfuse = 0xFF;
      hfuse = 0xDE;
      efuse = 0xFD;
      doNext = 0;
      base = 99;
    else if (inputString.startsWith("L", 0)) {
      Serial.print(F("Proposed Low Fuse  "));
      inputString = inputString.substring(1);
      evalString();
      if (base > 0) {
        lfuse = val1;
        doNext = 1;
    else if (inputString.startsWith("H", 0)) {
      evalString();
      if (base > 0) {
        hfuse = val1;
        doNext = 1;
    else if (inputString .startsWith("X", 0)) {
      evalString();
      if (base > 0) {
        efuse = val1;
        doNext = 1;
    if (base > 0 && base < 20) {
      printHex(val1);
      printBits(val1);
      Serial.println();
    else if (base == 99);  // print nothing
    else if (inputString == "W") {
      Serial.println(F("Write"));
      doNext = 4;
    else if (inputString == "R") {
      Serial.println(F("Read"));
      doNext = 3;
    else {
      Serial.println("Invalid input");
      doNext = 0;
    // clear the string:
    inputString = "";
    base = 0;
  // get new serial input and store in a String
  getSerialCharacters();
} //end of loop
void getSerialCharacters() { // get serial input
  static unsigned long serTimeoutCounter;
  if (Serial.available()) {
    char inChar = (char)Serial.read();
    if (inChar == '\n' && inputString != "") {
      stringComplete = true;
    else {
      if (inChar > 32 && inputString.length() < 25) {
        inputString += inChar;
        serTimeoutCounter = millis();
  if (millis() > SERIALTIMEOUT &&
      serTimeoutCounter < millis() - SERIALTIMEOUT &&
} // end of getSerialCharacters
void evalString() {  // interpret the numbers and convert from hex, decimal, or binary as needed
  inputString.toUpperCase();
  //  Serial.print("String: ");
  //  Serial.println(inputString);
  if (inputString.startsWith("NUM", 0)  &&
      (inputString.substring(3, 4) >= "0" && inputString.substring(3, 4) <= "9" )) {
    //    Serial.println("decimal number");
    base = 10;
    inputString = inputString.substring(3);
  else if (inputString.startsWith("BIN", 0) &&
           (inputString.substring(3, 4) >= "0" && inputString.substring(3, 4) <= "1" )) {
    //    Serial.println("binary number");
    base = 2;
  else if (inputString.startsWith("0X", 0)  &&
           ((inputString.substring(2, 3) >= "0" && inputString.substring(2, 3) <= "9" ) ||
            (inputString.substring(2, 3) >= "A" && inputString.substring(2, 3) <= "F" ))) {
    //    Serial.println("hex number");
    base = 16;
  else if ((inputString.substring(0, 1) >= "0" && inputString.substring(0, 1) <= "9" ) ||
           (inputString.substring(0, 1) >= "A" && inputString.substring(0, 1) <= "F" )) {
    base = 16;
  int stringlength = inputString.length() + 1;
  char char_array[stringlength];
  inputString.toCharArray(char_array, stringlength);
  if (base != 0) {
    char * pEnd;
    val1 = strtol(char_array, &pEnd, base);
    if (val1 > 255) {
      base = 0;
} // end of evalString
void printBits(byte myByte) {
  for (byte mask = 0x80; mask; mask >>= 1) {
    if (mask  & myByte)
      Serial.print('1');
    else
      Serial.print('0');
void printHex(byte myByte) {
  Serial.print(myByte / 16, HEX);
  Serial.print(myByte % 16, HEX);
void send_cmd(byte command)  // Send command to target AVR
  // Set controls for command mode
  digitalWrite(XA1, HIGH);
  if (mode != TINY2313)
    digitalWrite(BS2, LOW);  // Command load seems not to work if BS2 is high
  // set data pins to the value of command;
  digitalWrite(DATA0, bitRead(command, 0));
  digitalWrite(DATA1, bitRead(command, 1));
  digitalWrite(DATA2, bitRead(command, 2));
  digitalWrite(DATA3, bitRead(command, 3));
  digitalWrite(DATA4, bitRead(command, 4));
  digitalWrite(DATA5, bitRead(command, 5));
  digitalWrite(DATA6, bitRead(command, 6));
  digitalWrite(DATA7, bitRead(command, 7));
  // Set all DATA lines to outputs
  pinMode(DATA0, OUTPUT);
  pinMode(DATA1, OUTPUT);
  pinMode(DATA2, OUTPUT);
  pinMode(DATA3, OUTPUT);
  pinMode(DATA4, OUTPUT);
  pinMode(DATA5, OUTPUT);
  pinMode(DATA6, OUTPUT);
  pinMode(DATA7, OUTPUT);
  strobe_xtal();  // latch DATA
  // reset DATA to input to avoid bus contentions
void fuse_burn(byte fuse, int select)  // write high or low fuse to AVR
  send_cmd(B01000000);  // Send command to enable fuse programming mode
  // Enable data loading
  digitalWrite(XA0, HIGH);
  // Specify low byte
  delay(1);
  // Load fuse value into target
  // set data pins to value of fuse;
  digitalWrite(DATA0, bitRead(fuse, 0));
  digitalWrite(DATA1, bitRead(fuse, 1));
  digitalWrite(DATA2, bitRead(fuse, 2));
  digitalWrite(DATA3, bitRead(fuse, 3));
  digitalWrite(DATA4, bitRead(fuse, 4));
  digitalWrite(DATA5, bitRead(fuse, 5));
  digitalWrite(DATA6, bitRead(fuse, 6));
  digitalWrite(DATA7, bitRead(fuse, 7));
  // Decide which fuse location to burn
  switch (select) {
    case HFUSE_SEL:
      digitalWrite(BS1, HIGH); // program HFUSE
      break;
    case LFUSE_SEL:
      digitalWrite(BS1, LOW);  // program LFUSE
      break;
    case EFUSE_SEL:
      digitalWrite(BS1, LOW);  // program EFUSE
      digitalWrite(BS2, HIGH);
      break;
  delay(1);
  // Burn the fuse
  delay(1);
  //delay(100);
  while (digitalRead(RDY) == LOW); // when RDY goes high, burn is done
  // Reset control lines to original state
byte fuse_read(int select) {
  byte fuse;
  send_cmd(B00000100);  // Send command to read fuse bits
  // Configure DATA as input so we can read back fuse values from target
  // Set control lines
  switch (select) {
    case LFUSE_SEL:
      // Read LFUSE
      break;
    case HFUSE_SEL:
      // Read HFUSE
      break;
    case EFUSE_SEL:
      // Read EFUSE
      break;
  //  Read fuse
  delay(1);
  // read data pins and set value in variable fuse
  fuse = digitalRead(DATA7) << 7 |
         digitalRead(DATA6) << 6 |
         digitalRead(DATA5) << 5 |
         digitalRead(DATA4) << 4 |
         digitalRead(DATA3) << 3 |
         digitalRead(DATA2) << 2 |
         digitalRead(DATA1) << 1 |
         digitalRead(DATA0);
  digitalWrite(OE, HIGH);  // Done reading, disable output enable line
  return fuse;
byte HVSP_read(byte data, byte instr) { // Read a byte using the HVSP protocol
  byte response = 0x00; // a place to hold the response from target
  digitalWrite(SCI, LOW);  // set clock low
  // 1st bit is always zero
  sclk();
  // We capture a response on every readm even though only certain responses contain
  // valid data.  For fuses, the valid response is captured on the 3rd instruction write.
  // It is up to the program calling this function to figure out which response is valid.
  // The MSB of the response byte comes "early", that is,
  // before the 1st non-zero-padded byte of the 3rd instruction is sent to the target.
  // For more information, see the ATtiny25/45/85 datasheet, Table 20-16 (pg. 164).
  if (digitalRead(SDO) == HIGH) // target sent back a '1'?
    response |= 0x80;  // set MSB of response byte high
  // Send each bit of data and instruction byte serially, MSB first
  // I do this by shifting the byte left 1 bit at a time and checking the value of the new MSB
  for (int i = 0; i < 8; i++) { // i is bit number
    if ((data << i) & 0x80)  // shift data byte left and check if new MSB is 1 or 0
      digitalWrite(SDI, HIGH);  // bit was 1, set pin high
    else
      digitalWrite(SDI, LOW);   // bit was 0, set pin low
    if ((instr << i) & 0x80)   // same process for instruction byte
      digitalWrite(SII, HIGH);
    else
    sclk();
    if (i < 7) {  // remaining 7 bits of response are read here (one at a time)
      // note that i is one less than the bit position of response we are reading, since we read
      // the MSB above.  That's why I shift 0x40 right and not 0x80.
      if (digitalRead(SDO) == HIGH) // if we get a logic 1 from target,
        response |= (0x40 >> i);    // set corresponding bit of response to 1
  // Last 2 bits are always zero
  for (int i = 0; i < 2; i++) {
    sclk();
  return response;
void HVSP_write(byte data, byte instr) { // Write to target using the HVSP protocol
  sclk();  // latch bit
    else
    else
    sclk();  // strobe SCI (serial clock) to latch data
    sclk();
void sclk(void) {  // send serial clock pulse, used by HVSP commands
  // These delays are much  longer than the minimum requirements,
  // but we don't really care about speed.
  delay(1);
  delay(1);
void strobe_xtal(void) {  // strobe xtal (usually to latch data on the bus)
  delay(1);
  digitalWrite(XTAL1, HIGH);  // pulse XTAL to send command to target
  delay(1);
  digitalWrite(XTAL1, LOW);
timtim1234
Joined Nov 30, 2023
246
Code:
Removed run button
Removed ASKMODE
  Pro Mini, Nano
1 2 3 set mode
W write fuses
R read fuses
// Pin Assignments
#define DATA0 A1
#define DATA1 1
#define DATA2 2
#define DATA3 3
#define DATA4 4
#define DATA5 5
#define DATA6 6
#define DATA7 7
#define  VCC     12
#define  OE      11
#define  WR      10
#define  BS1     A2
#define  XA0     8
#define  XA1     A4
#define  XTAL1   A3
#define  PAGELM  A5
#define  BS2M    9
#define  SCI    BS1
#define  SDO    RDY
#define  SII    XA0
#define  SDI    XA1
// LFUSE
// HFUSE
// EFUSE
// Global variables
long val1;
byte base = 0;
byte lfuse = LFUSE;
byte hfuse = HFUSE;
byte efuse = EFUSE;
byte BS2 = BS2M;
  delay(50);
  while (!Serial) ;
#endif
  Serial.println();
}  // end of setup
  if (doNext == 0) {
#endif
    switch (mode) {
      case ATMEGA:
        break;
      case TINY2313:
        break;
      case HVSP:
        break;
    printHex(lfuse);
    printBits(lfuse);
    Serial.println();
    printHex(hfuse);
    printBits(hfuse);
    Serial.println();
    printHex(efuse);
    printBits(efuse);
    Serial.println();
    doNext = 1;
    doNext = 2;
    Serial.end();
    delay(50);
    if (mode == HVSP) {
    if (mode == HVSP) {
    delay(1);
    if (mode == HVSP) {
#endif
    } else {
#endif
    delay(1);
    Serial.begin(BAUD);
    delay(50);
    Serial.println();
    Serial.println();
    Serial.println();
    Serial.println();
#endif
    Serial.println();
    doNext = 1;
#endif
#endif
    delay(50);
    if (mode == HVSP) {
    if (mode == HVSP) {
    delay(1);
    if (mode == HVSP) {
#endif
    } else {
      //delay(10);
#endif
    delay(50);
    Serial.println();
    delay(1);
    evalString();
      PAGEL = PAGELM;
      BS2 = BS2M;
      mode = ATMEGA;
      doNext = 1;
      base = 99;
      PAGEL = PAGELT;
      BS2 = BS2T;
      mode = TINY2313;
      doNext = 1;
      base = 99;
      PAGEL = PAGELM;
      BS2 = BS2M;
      mode = HVSP;
      doNext = 1;
      base = 99;
      lfuse = LFUSE;
      hfuse = HFUSE;
      efuse = EFUSE;
      doNext = 0;
      base = 99;
      lfuse = 0xFF;
      hfuse = 0xDE;
      efuse = 0xFD;
      doNext = 0;
      base = 99;
      evalString();
      if (base > 0) {
        lfuse = val1;
        doNext = 1;
      evalString();
      if (base > 0) {
        hfuse = val1;
        doNext = 1;
      evalString();
      if (base > 0) {
        efuse = val1;
        doNext = 1;
      printHex(val1);
      printBits(val1);
      Serial.println();
      doNext = 4;
      doNext = 3;
    else {
      doNext = 0;
    inputString = "";
    base = 0;
} //end of loop
    else {
    base = 10;
    base = 2;
    base = 16;
    base = 16;
  if (base != 0) {
    char * pEnd;
    if (val1 > 255) {
      base = 0;
    if (mask  & myByte)
      Serial.print('1');
    else
      Serial.print('0');
  // Specify low byte
  delay(1);
  switch (select) {
    case HFUSE_SEL:
      break;
    case LFUSE_SEL:
      break;
    case EFUSE_SEL:
      break;
  delay(1);
  // Burn the fuse
  delay(1);
  //delay(100);
  byte fuse;
  switch (select) {
    case LFUSE_SEL:
      // Read LFUSE
      break;
    case HFUSE_SEL:
      // Read HFUSE
      break;
    case EFUSE_SEL:
      // Read EFUSE
      break;
  //  Read fuse
  delay(1);
         digitalRead(DATA0);
  return fuse;
  sclk();
    else
    else
    sclk();
    sclk();
  return response;
    else
    else
    sclk();
  delay(1);
  delay(1);
  delay(1);
  delay(1);
ahh ok :) well its good to have :) thanks
LesJones
Joined Jan 8, 2017
4,544
Re posts #206 & #209 When the 15Min_timer.hex ran fast after programming the ATtiny 85 with the boot loader the 15 minutes would also be shorter. I think configuring the chip with the boot loader also changed the CKDIV8 bit in the low fuse byte, By default it divides the 8.0 Mhz internal clock so the cpu is clocked with 1 Mhz . The cpu clock also feeds into the timer/counter0 via it's prescaler. With my chosen prescaler setting of 64, the counter set to count 252 we get an interupt every 26,128 mS. we then count 62 of these interrupts which gives us 999.936 mS. So this is very close to 1 second if the internal clock is exaclly 8.0 Mhz
This is then divided by 60 to give minutes and then by 15 to give a pulse every 15 minutes. That bit change did not prevent it from being programmed normally. I did have to to use a high voltage programmer after making a mistake when configuring it to use an external crystal. Tha programmer I used is the same sort that has been mentioned in some other posts. At the moment I can't get the arduino programmer to work. I don't know what has changed since it did work. You posted an example showing 3 shevron prompts.
This is a screenshot of the command lines I have been using.
I an using avrdude 6.0.1 with windows 7. (Note this version seems to sawp over the display of the low byte and extended fuse bytes.
Les.
be80be
Joined Jul 5, 2008
2,395
He probably made a folder Like i posted
You make a folder call it flash copy avrdude and avrdude.conf to that then go to the folder add your hex and load from that folder it lot easier
timtim1234
Joined Nov 30, 2023
246
Les.
1). From what it sounds like, it was shorter by 1 sec? If so, that not a big deal. If a person needs it to be exact then use a pot and have the code do 16 or 20 mins then adjust the pot to the time that is need.
2). Looks like from the command line, you are using an usbasp programmer? If so that is why the arduino programmer is not working.
3). Truth be told, I have tried the "command" direct for avrdude yet. I have been using avrdudeness GUI program when I did the reads outputs i posted in the other post
also i got my HVP prgrammer built!! i just have to test it yet :)
LesJones
Joined Jan 8, 2017
4,544
Re post #228
Point 1 disableing the the CKDIV8 divider does not just reduce the 15 minutes by 1 second. I divides the 15 minutes by 8. (so it would now be 900/8 = 112,5 seconds = 1 minute 52.5 seconds. the 1 second pulse would be a 125 mS pulse.
Point 2 I was using an USBasp programer to demonstrate what it looks like when it is working. Whwn using the arduino as a programmer "usbasp" would be replaced with "arduinoisp".
Point 3 when I tried avrdudess it would not even work with the a usbasp programmer. It seems to use avrdude 7.3 which I have now found does not support usbasp programmers. (I have now removed avrdudess from my computer.)
I have now found out that the "burn bootoader" command in the arduino IDE does not write the boot loader code to the ATtiny85
I only changes the state of the CKDIV8 bit in the low fuse byte. This explains why the burn bootloader command appears to work but all the flash memory read back as FF's
Les.
timtim1234
Joined Nov 30, 2023
246
Re post #228
Les.
1). ahhh ok "1 minute 52.5 seconds. The 1-second pulse would be a 125 mS pulse" that can be made up within the code or by using a variable potentiometer circuit. i am not sure, maybe I am not understanding why would a person disable the CKDIV8?
If I recall, that has nothing to do with lock bits? Or it does?
2). ohh ok i didn't realize you have a USBasp programmer. What error do you get when you use the arduino?
3). When you tried the avrdudess using the arduino programmer, i would assume you change the programmer type to what i posted?
LesJones
Joined Jan 8, 2017
4,544
Re post #236.
1 The main reason for disabling the divide by 8 is to clock the cpu at 8 Mhz (Rather than 1 Mhz) as this is the value required when you set up the Arduino to us the ATtiny 85.
2 I have used a USBasp programmer since I first started programming atmel 8 bit microcontrollers about 10 years ago. I have never had any problems using the USBasp programmers.
Here a screen capture of using the arduino isp programmer. I don't think it is comunicating with the ATtiny85 as it can't even read the signature byte.
3 I did not try to use avrduess in the same way as you did.
