I apologize, i was not aware that voltage had a strong influence in switches. The maximum voltage would be about 2.5V since the circuit is part of a wheatstone bridge where the bridge voltage is 2.5VIf you only need to switch 5V, then the SN74CB3T16211, which has an on-resistance of <10Ω should work fine.
I don't believe you ever stated what maximum voltage you need to switch(?).
